Author Topic: How to use mouse-click  (Read 13153 times)
« on: January 23, 2016, 12:51:10 AM »
I found a demo LED scoreboard, that is controlled by mouse-click.
How do i do that in GeeXLab, sth. with gh_input.mouse_get_button_state() ?
EDIT: solution below
As a work-around i replaced mouse-click with mouse-over in the pixel shader
    vec3 col = iMouse.w > 0.5 ? flag( DE ) : flag( RU );
    if ( p.x > 0.5 + halfStripe ){ col = iMouse.w > 0.5 ? flag( RU ) : flag( DE ); }
replaced with
    vec3 col = iMouse.x > 0.5*iResolution.x ? flag( DE ) : flag( RU );
    if ( p.x > 0.5 + halfStripe ){ col = iMouse.x > 0.5*iResolution.x ? flag( RU ) : flag( DE ); }
>>>Get ported version here<<<
« Last Edit: January 25, 2016, 02:17:02 AM by Stefan »
Re: How to use mouse-click
« Reply #1 on: January 24, 2016, 10:44:01 PM »
Here is another demo: 2D Radial Repeat : Hex RadClick
Besides mouse i patched other issues.
section id
shifted to bottom left of the screen, away from GeeXLab's overlay
uv.x += iDate.w ; // rotate each radius offset with constant speed
doesn't work, replaced with
uv.x += iGlobalTime ;
mouse click
if(iMouse.z>0.) pos = iMouse.xy;
replaced with mouse over
if(iMouse.x>20.) pos = iMouse.xy;
« Last Edit: January 24, 2016, 10:53:40 PM by Stefan »
« Reply #2 on: January 25, 2016, 02:15:40 AM »
OK,
got it working now
local mx, my = gh_input.mouse_getpos()
local mz = gh_input.mouse_get_button_state(1)
local mw = mz
gh_gpu_program.uniform4f(shadertoy_prog, "iMouse", mx, -(my - winH), mz, mw)
I will add both mouse-click and mouse-over versions to next demo pack.
« Last Edit: January 25, 2016, 02:55:58 AM by Stefan »
« Reply #3 on: January 25, 2016, 08:36:52 PM »
Indeed I just noticed that there is no a code sample focused on the mouse (while there is a keyboard/ folder in the code sample pack). The mouse is used in many code samples so browsing the code sample pack is a solution. Another faster solution is to look at the libs folder shipped with GeeXLab.
In GeeXLab/libs/lua/ there are several Lua files that use the mouse, like this one: gx_cam_lib_v2.lua
Anyway, you have found the solution and that's the important thing!
« Reply #4 on: January 26, 2016, 06:19:43 PM »
Here is a pack with mouse-click controlled shaders
I remember to have stumbled over Shadertoy demos with keyboard control, but i passed on them because the keyboard is stuffed in an iChannel
I take another look if i find these demos again...
Where the River Goes - yet another GPU burner
« Reply #5 on: January 29, 2016, 08:58:55 PM »
>>>ported to GeeXLab<<<
Click mouse to change view
#define ENABLE_ULTRA_QUALITY  to fry your GPU, frame rate drops to 10%
