Author Topic: GeeXLab 0.9.1.0 released  (Read 16673 times)
« on: December 04, 2015, 07:44:16 PM »
GeeXLab 0.9.1.0 for Windows is available:
http://www.geeks3d.com/hacklab/20151204/geexlab-0-9-1-0-released-for-windows-32-and-64-bit/
Versions for other OSes will be available very soon.
GeeXLab 0.9.1.0 for Linux released
« Reply #1 on: December 05, 2015, 01:52:32 PM »
GeeXLab 0.9.1.0 for OS X released
« Reply #2 on: December 07, 2015, 10:17:54 AM »
GeeXLab 0.9.1.0 Raspberry Pi released
« Reply #3 on: December 07, 2015, 10:18:38 AM »
Re: GeeXLab 0.9.1.0 Raspberry Pi released
« Reply #4 on: December 08, 2015, 07:15:29 AM »
The Raspberry Pi version of GeeXLab is available:
Coincidentiially someone made a raspberry shader the other day.
So if you to want to see a raspberry on your Raspberry, download it here
Another thing:
Will you make a shadertoy_prog, "iDate" sometime?
I tried to port a clock shader which stalled in GeeXLab.
EDIT:
I didn't find cubemap/texturecube support in gfx02.lua. How to do that?
« Last Edit: December 09, 2015, 11:52:08 AM by Stefan »
Re: GeeXLab 0.9.1.0 released
« Reply #5 on: December 11, 2015, 01:59:54 PM »
I just published a post that should help you to get iDate in your demos:
http://www.geeks3d.com/hacklab/20151211/lua-date-and-time-shadertoy-idate/
For the cubemap, you can do it yourself  directly in the demo. To load a cubemap (6 images) use this code:
local pf = 3
local abs_path = 0
cubemap = gh_texture.create_cube_from_file("./data/skybox08_posx.jpg", "./data/skybox08_negx.jpg", "./data/skybox08_posy.jpg", "./data/skybox08_negy.jpg", "./data/skybox08_posz.jpg", "./data/skybox08_negz.jpg", pf, abs_path, 0)
To use a cube map in a Shadertoy demo (the cubemap is bound to the sampler iChannel1 in the Shadertoy pixel shader):
gh_texture.bind(tex0, 0)
gh_texture.bind(cubemap, 1)
gh_texture.bind(tex2, 2)
gh_gpu_program.bind(shadertoy_prog)
gh_gpu_program.uniform1f(shadertoy_prog, "iGlobalTime", elapsed_time)
gh_gpu_program.uniform1i(shadertoy_prog, "iChannel0", 0);
gh_gpu_program.uniform1i(shadertoy_prog, "iChannel1", 1);
gh_gpu_program.uniform1i(shadertoy_prog, "iChannel3", 2);
The cubemap is defined as follows in a shadertoy demo:
uniform sampler2D iChannel0;
uniform samplerCube iChannel1;
uniform sampler2D iChannel3;
There is a shadertoy demo in the code sample pack that uses cubemaps:
host_api/GLSL_ShaderToy/cells.xml
« Reply #6 on: December 11, 2015, 08:12:40 PM »
Thanks, there is a typo in line 5, it must read:
gh_gpu_program.uniform4f(shadertoy_prog, "iDate", tmp.year, tmp.month, tmp.day, time_seconds)
Here is the ported clock shader
« Reply #7 on: December 13, 2015, 08:28:27 PM »
Just tried the 32 bit version under Windows XP
leap.dll refuses to load because procedure entry point "GetNamedPipeClientProcessId" is missing in KERNEL32.dll
As a workaround i deleted leap.dll
« Reply #8 on: December 24, 2015, 10:10:15 AM »
Another tidbit with the 32 bit version: overlay reads 64 bit
FYI: users with antiquated GPUs can run GeeXLab with MESA, using pre-compiled binary from here
