Author Topic: Shadering Chameleon V2.0 vs. Intel graphics  (Read 12614 times)
« on: December 01, 2015, 10:05:28 PM »
I converted Shadering Chameleon V2.0 into GLSL hacker format, download (fixed) code here
Works fine at Shadertoy.com with Intel graphics, but not when running in GLSL hacker.
Most body parts are missing.
No problem with NVIDIA
« Last Edit: December 06, 2015, 10:16:39 PM by Stefan »
Re: Shadering Chameleon V2.0 vs. Intel graphics
« Reply #1 on: December 04, 2015, 07:34:42 PM »
I'll try to check this demo later. Probably an bug in Intel desktop OpenGL driver...
Similar graphics bugs: http://www.geeks3d.com/forums/index.php/topic,3928.0.html
« Reply #2 on: December 06, 2015, 02:33:04 PM »
I've triple-checked with my legacy AMD APU, here only the head is missing.
btw the code for the body parts is titled inside the pixel shader.
« Reply #3 on: December 06, 2015, 08:52:00 PM »
The head is missing here too. But it seems you have tweaked a bit the code in the map() function (around line 197). I copied the original map()  function from Shadertoy website and the chameleon looks good with a GTX 960:
I will check the demo with the Intel HD 530 asap.
« Reply #4 on: December 06, 2015, 08:54:27 PM »
By the way, I added this demo to the code sample pack. Thanks Stefan for the port ;)
« Reply #5 on: December 06, 2015, 10:06:26 PM »
Yes, i tried to shuffle the code to see if it makes a difference on Intel.
Then i uploaded a screwed version,
The original shader works on NVIDIA and AMD
