Qualcomm Adreno GPU drivers November 2015
Started by Stefan, November 10, 2015, 09:22:00 PM
User-mode driver binaries for Qualcomm Adreno 3xx/4xx GPU on Nexus 5, 6 & 7 devices running Google Android Marshmallow
Adreno Driver Update Installation Instructions Requirements This release is certified for use on Nexus 5/6/7 devices with following factory image installed.
Instructions Optional Steps These steps describe how to install a clean Google factory image onto your device. THIS WILL PERFORM A FACTORY RESET AND ERASE ALL YOUR DATA. It is not necessary to perform these steps, but you may wish to if you try this driver with a release of Android other than stock image is has been tested on.
IMPORTANT: If you are using a Nexus 6 device, please disable Device Protection prior to installing factory ROM images, or you may lose access to your device. Please see this article for more information.
  • Download and install the factory ROM for your device and install it according to Google's instructions.
  • Boot the device and perform the initial setup steps as described by the onscreen prompts.
Required Steps
  • Download and install the TWRP recovery image for your device, according to the instructions on the TeamWin site.
  • Reboot the device in recovery mode.
  • Put the TWRP recovery image in sideload mode by following these instructions.
  • Send the Adreno libraries update to the device by typing adb sideload <filename> on your host computer, where <filename> is replaced by one of the following, appropriate for your device:
  • Reboot the device by following the onscreen prompts.
