AMD GPU PerfAPI 2.17
Started by Stefan, August 25, 2015, 06:57:58 PM
 Release Notes – Version 2.17 (8/12/15)
  • Add support for additional GPUs and APUs.
  • Add OpenGL ES support for both Windows and Linux.
  • DirectX 11/OpenGL: Add CSFlatVMInsts and CSFlatLDSInsts counters to measure flat instructions used for compute shaders on 2nd Generation GCN hardware or newer.
  • DirectX11/OpenGL: Fix CSLDSInsts, CSVWriteInsts, CSVFetchInsts counter on 2nd Generation GCN hardware or newer.
  • DirectX 11: Fixed a crash that could occur on Multi-GPU systems.
  • OpenGL: rework the GPUTime implementation so that GPA no longer needs to stop/start any existing queries that the application may be using.
  • OpenCL™: Add FlatVMInsts and FlatLDSInsts counters to measure flat instructions used for OpenCL kernels on 2nd Generation GCN hardware or newer.
  • OpenCL™: Fix LDSInsts, VWriteInsts, VFetchInsts counter on 2nd Generation GCN hardware or newer.
  • OpenCL™: Fix MemUnitBusy counter on 2nd Generation GCN hardware or newer.
  • Fix a potential crash in GPA_SelectContext.
  • Fix a bug in GPA_DisableCounter that could result in the counter not actually getting disabled.
