Author Topic: The Institute converted  (Read 10664 times)
« on: June 03, 2015, 05:24:15 PM »
The Institute converted to GLSL Hacker format
Copy the code and save as the_institute_gl2.xml in demo folder of MadShaders.
Works fine with NVIDIA Maxwell, but fails to compile with my old AMD APU.
« Last Edit: June 09, 2015, 05:15:52 PM by Stefan »
Re: The Institute converted
« Reply #1 on: June 09, 2015, 05:20:09 PM »
It appears that the variable name "layout" is illegal exclusively on AMD GPUs
Updated code with fix below
<?xml version="1.0" encoding="ISO-8859-1" standalone="yes"?>
<glsl_hacker>
  <window name="win3d01" title="MadShaders - Shadertoy/The Institute"
          width="800" height="400"
          gl_version_major="2" gl_version_minor="1" />
<gpu_program name="shadertoy_prog" >
    <raw_data_vs><![CDATA[
void main()
    gl_TexCoord[0] = gl_MultiTexCoord0;
  gl_Position = gl_ModelViewProjectionMatrix * gl_Vertex;
  ]]></raw_data_vs>
    <raw_data_ps><![CDATA[
// https://www.shadertoy.com/view/Xll3Wn
uniform vec3      iResolution;     // viewport resolution (in pixels)
uniform float     iGlobalTime;     // shader playback time (in seconds)
uniform vec4      iMouse;          // mouse pixel coords. xy: current (if MLB down), zw: click
// illegal variable name "layout" replaced with "yikes"
//The Institute by eiffie
#define time iGlobalTime
#define size iResolution
#define AUTO_OVERSTEP
float px;
vec4 prp=vec4(0.0);
vec3 L;
float rnd(vec2 c){return fract(sin(dot(vec2(1.317,19.753),c))*413.7972);}
float rndStart(vec2 gl_FragCoord){
    return 0.5+0.5*rnd(gl_FragCoord.xy);
float smin(float a,float b,float k){float h=clamp(0.5+0.5*(b-a)/k,0.0,1.0);return b+h*(a-b-k+k*h);}
float noyz(vec2 p){//value noise - original author??
    vec2 c=floor(p),f=fract(p);f=f*f*(3.0-2.0*f);
    float k=257.0,u=c.x+c.y*k;
    vec4 v=vec4(u,u+1.0,u+k,u+k+1.0);v=fract(fract(v*1.23456789)*9.18273645*v);
    return mix(mix(v.x,v.y,f.x),mix(v.z,v.w,f.x),f.y);
float fbm(vec2 p){
    vec2 s=sin(p*0.3+2.4*sin(p.yx*0.3));
    float h=1.0+(s.x+s.y)*0.5,a=0.5;
    p+=s.yx*0.66;
    for(int i=0;i<3;i++){
        h+=noyz(p)*a;
        a*=0.3;p=vec2(p.x+p.y*0.7,p.x-p.y+0.13)*2.0;
    return h;
vec3 Sky(vec3 rd){
    vec3 col=mix(vec3(0.4,0.2,0.0),vec3(0.5,0.7,0.7),clamp(0.25-0.5*rd.z,0.0,1.0));
    col+=vec3(1.2,1.1,0.9)*pow(max(0.0,dot(rd,L)),100.0);
    float h=noyz(rd.xy*5.0)*0.5+noyz(vec2(2.0*abs(atan(rd.y,rd.x)),rd.z*20.0));
    col=mix(col,vec3(0.9,0.8,0.6),clamp(h*0.5-0.4,0.0,1.0));
    return mix(vec3(0.1,0.2,0.1),col,clamp((-rd.z+0.05)*20.0,0.0,1.0));
float capsule(vec3 p){return length(vec3(p.x,p.y-clamp(p.y,-3.0,10.0),p.z));}
float rcap(vec3 p){return length(vec2(p.x-clamp(p.x,-7.0,7.0),max(abs(p.y),abs(p.z))));}
float DE(in vec3 p){
    float yikes=(length(p.xy+vec2(8.0,-6.0))-45.0);
    yikes=smin(yikes,abs(p.y-28.0+sin(p.x*0.01)*40.0)-5.0,20.0)*0.02;
    float h=fbm(p.xy*0.1)*10.0*pow(clamp(yikes,0.0,1.0),0.7),d=-p.z+7.0-h,dG=d;
    for (int n = 0; n < 4; n++) {
        p=clamp(p, -3.1, 3.1) *2.0-p;
        p+=vec3(1.9,3.2,8.6);
        p=p.yzx;
        d=min(d,min(capsule(p)-3.0,rcap(p)-2.0));
    if(d<0.25 && d<dG){
        float flr=floor(p.y);
        float rs=1.0+sin(flr)*0.5;
        p=vec3(rs,1.0,rs)*0.5-abs(mod(p,vec3(rs,1.0,rs))-vec3(rs,1.0,rs)*0.5);
        float d2=d+0.05;
        if(flr<-rs || rs<0.6)
            d=min(d2,max(d,min(p.y,min(p.x,p.z))-0.0125));
        else if(flr<rs*2.0 || rs<0.75)
            d=max(d,min(p.y,min(p.x,p.z))-0.025);
        else {
            d=max(d,min(p.y,max(p.x,p.z))-0.05);
            if(prp.x<0.0)prp=vec4((rs>1.3)?length(p):10.0,0.0,0.0,(max(p.x,p.z)<0.06)?4.0:3.0);
        if(prp.x<0.0){
            if(d==d2)prp=vec4(10.0,0.0,0.0,2.0);
            else prp=vec4(10.0,0.0,0.0,3.0);
    }else if(prp.x<0.0)prp=vec4(10.0,h,yikes,1.0);
    return d;
float shadao(vec3 ro, vec3 rd, float px,vec2 gl_FragCoord){//pretty much IQ's SoftShadow
    float res=1.0,d,t=10.0*px*rndStart(gl_FragCoord);
    for(int i=0;i<12;i++){
        d=max(0.0,DE(ro+rd*t)*1.5);
        t+=d;
        res=min(res,d/t);
    return res;
vec3 Color(vec3 ro, vec3 rd, float t, vec3 col, bool bFill, vec2 gl_FragCoord){
    ro+=rd*t;
    prp.x=-1.0;
    float d=DE(ro),spec=0.0,n=noyz(ro.xy*3.0);
    vec2 e=vec2(px*t,0.0);
    vec3 dn=vec3(DE(ro-e.xyy),DE(ro-e.yxy),DE(ro-e.yyx));
    vec3 dp=vec3(DE(ro+e.xyy),DE(ro+e.yxy),DE(ro+e.yyx));
    vec3 N=(dp-dn)/(length(dp-vec3(d))+length(vec3(d)-dn));
    vec3 R=reflect(rd,N);
    vec3 lc=vec3(1.0,0.9,0.,sc,rc=Sky(R);
    if(prp.w<1.5){
        sc=mix(vec3(0.8,0.8,0.3),vec3(0.2),clamp(abs(abs(ro.y-28.0+sin(ro.x*0.01)*40.0)-0.25)*4.0,0.0,1.0));
        sc=mix(sc,mix(vec3(0.2,0.3,0.1),vec3(0.6,0.5,0.4),clamp(prp.y*0.05-0.25,0.0,1.0)),clamp(prp.z*100.0,0.0,1.0));
        spec=0.2;//clamp(2.5-prp.y,0.0,1.0);
        n*=0.1;
    }else if(prp.w<2.5){sc=vec3(0.4,0.5,0.6);spec=1.0;n*=0.3;
    }else if(prp.w<3.5){sc=vec3(0.6,0.63,0.62);spec=0.5;n*=0.4;}
    else {sc=vec3(0.5,0.5,0.0);spec=0.5;}
    sc*=(1.0-n);
    float sh=clamp(shadao(ro,L,px*t,gl_FragCoord)+0.2,0.0,1.0);
    sh=sh*(0.5+0.5*dot(N,L))+exp(-prp.x*5.0);
    vec3 scol=sh*lc*(sc+0.5*spec*rc*pow(max(0.0,dot(R,L)),2.0));
    if(bFill)d*=0.05;
    col=mix(scol,col,clamp(d/(px*t),0.0,1.0));
    return col;
mat3 lookat(vec3 fw){
    fw=normalize(fw);vec3 rt=normalize(cross(fw,vec3(0.0,0.0,-1.0)));return mat3(rt,cross(rt,fw),fw);
vec3 cpnt(float t){
    if(t<0.5)return vec3(-45.0,30.0,-38.0);
    if(t<1.5)return vec3(-20.0,23.0,-25.0);
    if(t<2.5)return vec3(-13.0,23.0,-2.5);
    if(t<3.5)return vec3(10.0,26.0,-2.5);
    return vec3(12.0,21.0,6.6);
vec3 path(float t){
    float t2=t-t*t*0.05;
    if(t<10.0)return vec3(-1000.0+t2*200.0,30.0-sin((-1000.0+t2*200.0)*0.01)*40.0,4.25);
    t2=time-10.0;
    float r=60.0-t2;
    if(t<25.0)return vec3(-8.0+r*cos(t2*0.3),6.0+r*sin(t2*0.25),-t2*4.0);
    if(t<45.0){
        t2=(t-25.0)/5.0;r=floor(t2);t2=fract(t2);
        return mix(cpnt(r),cpnt(r+1.0)-0.25*cpnt(r+2.0)*(1.0-t2),t2);
    if(t<60.0){
        t2=t-45.0;
        t2=t2-t2*t2*0.025;
        r=500.0-t2*50.0;
        vec3 p=vec3(cos(t2*0.2)*r,sin(t2*0.2)*r,-30.0);
        float d1=DE(p),d2=DE(p+vec3(0.0,-10.0,0.0));
        p.z+=(d1+d2)*0.4;
        return p;
    return vec3(-8.0+cos(t*0.3)*60.0,6.0+60.0*sin(t*0.2),-29.5+sin(t*0.1)*10.0);
void main()
    px=0.5/size.y;
    L=normalize(vec3(0.5,0.3,-0.6));
    float tim=time;
    vec3 ro=path(tim);
    vec3 ta=path(tim+0.5);
    if(tim>10.0 && tim<25.0)ta=vec3(0.0);
    if(tim>60.0)ta=vec3(0.0,0.0,-20.0);
    vec3 rd=lookat(ta-ro)*normalize(vec3((2.0*gl_FragCoord.xy-size.xy)/size.y,3.0));
    //ro=eye*10.0;rd=normalize(dir);
    float t=DE(ro)*rndStart(gl_FragCoord),d=0.0,od=1.0,step=0.0,os=0.0,pd=10.0;
    if(t<0.0){
        gl_FragColor=vec4(0.0,0.0,0.0,1.0);
        return;
    vec4 edge=vec4(-1.0);
    bool bGrab=false;
    for(int i=0;i<78;i++){
        t+=step;
        d=DE(ro+rd*t);
#ifdef AUTO_OVERSTEP
        if(d>=os){        //we have NOT stepped over anything
            os=0.36*d*d/pd;//overstep based on ratio of this step to last
            step=d+os;    //add in the overstep
            pd=d;        //save this step length for next calc
        }else{step=-os;d=0.0001;pd=100000.0;os=0.0;}//remove overstep
#else
        step=d;
#endif
        if(d>od){
            if(bGrab && od<px*t && edge.x<0.0){
                edge=vec4(edge.yzw,t-od);
                bGrab=false;
        }else bGrab=true;
        od=d;
        if(t>1000.0 || d<0.00001)break;
    bool bFill=false;
    d*=0.05;
    if(d<px*t){
        if(edge.x>0.0)edge=edge.wxyz;
        edge=vec4(edge.yzw,t);
        bFill=true;
    vec3 col=Sky(rd);
    for(int i=0;i<4;i++){
        if(edge.w>0.0)col=Color(ro,rd,edge.w,col,bFill,gl_FragCoord);
        edge=edge.wxyz;
        bFill=false;
    float dimmer=clamp(min(abs(time-10.0),min(abs(time-25.0),min(abs(time-45.0),abs(time-60.0)))),0.0,1.0);
    gl_FragColor = vec4(1.5*col*dimmer*dimmer,1.0);
]]></raw_data_ps>
</gpu_program>
    <script name="init_scene" run_mode="INIT" >
        <raw_data><![CDATA[
app_dir = gh_utils.get_scripting_libs_dir()
dofile(app_dir .. "lua/Moon3D_v2.lua")
moon3d.init(2, 1)
moon3d.graphics.vsync(0)
bmfont = moon3d.font.create("trebuchet_20px.fnt", "data/")
bmfont_texture = moon3d.font.getTexture(bmfont)
moon3d.madshaders.setBmFontData(bmfont, bmfont_texture)
winW, winH = moon3d.window.getSize()
quad = moon3d.graphics.newQuad(winW, winH)
shadertoy_prog = moon3d.graphics.getGpuProgram("shadertoy_prog")
-- tex0 = moon3d.image.load2d("./data/tex16.png")
moon3d.madshaders.resetBenchmarkData()
        ]]></raw_data>
    </script>
    <script name="update_scene" run_mode="FRAME" >
        <raw_data><![CDATA[
moon3d.startFrame(0, 0, 0, 1)
local global_time = moon3d.getTime()
moon3d.madshaders.updateBenchmarkData(global_time)
moon3d.camera.bindOrtho()
moon3d.graphics.bindGpuProgram(shadertoy_prog)
moon3d.madshaders.updateShadertoyCommonParams(shadertoy_prog, global_time)
--moon3d.madshaders.setShadertoyTexture(shadertoy_prog, tex0, 0)
moon3d.graphics.draw(quad)
moon3d.madshaders.displayBenchmarkInfoV2("Shadertoy/The institute", global_time, 1, 1, 1, 1)
moon3d.endFrame()
        ]]></raw_data>
    </script>
    <script name="resize_scene" run_mode="SIZE" >
        <raw_data><![CDATA[
moon3d.window.resize()
moon3d.graphics.resizeQuad(quad, winW, winH)
        ]]></raw_data>
    </script>
</glsl_hacker>
« Reply #2 on: June 09, 2015, 05:58:34 PM »
That makes sense, because layout is a keyword in GLSL with OpenGL 3.2+. As usual, AMD is strict with GLSL compilation.
