This library provides software developers with the ability to query AMD GPU software and hardware state information that is not normally available through standard operating system or graphic APIs. The library includes support for querying graphics driver version info, Crossfire (AMD’s multi-GPU rendering technology) configuration info, as well as Eyefinity (AMD’s multi-display rendering technology) configuration info. AGS is available in dynamic and static library form for 32 and 64 bit versions of Microsoft® Windows® Vista, Windows 7 and Windows 8. Download it from the table below. What’s in the package: AMD GPU Services (AGS) Library (static and dynamic linked library for 32 and 64 bits version of Vista, Windows 7 and Windows 8) .
AGS sample, a console mode sample shows you how to query information from AGS library.
Eyefinity sample, a sample shows you how to use AGS library to query Eyefinity configuration information for your application. This sample also shows you how to use multiple cameras to render 3d scene with Eyefinity technology.
Changes in AGS v2.2:
Added new function to obtain the amount of installed memory on a GPU.
