Author Topic: Could not connect to server (04)  (Read 6415 times)
janixpl
« on: February 10, 2015, 07:12:33 PM »
Hello,
I am new here, and this is my first post on this forum.
I have a problem with GLSL Hacker. When I try run network GPU program live-updater, I have an error:
"Could not connect to server (04)."
I am using this program locally. I've tried change server address from localhost, to 127.0.0.1 and change port too. Nothing works :/
Anyone has this problem?
« Last Edit: February 10, 2015, 07:15:30 PM by janixpl »
Re: Could not connect to server (04)
« Reply #1 on: February 12, 2015, 09:32:51 AM »
In recent versions of GLSL Hacker, I disabled the internal TCP/IP server used for remote live coding.
To enabled it, start GLSL Hacker in command line with /start_tcpip_server:
GLSLHacker /start_tcpip_server
janixpl
« Reply #2 on: February 28, 2015, 12:13:23 AM »
Thank you very much.
