ISSUE with GPUTEST when running for 8 hour or more.
Started by macs, January 22, 2015, 04:20:29 PM
macs
hello, I found a Issue with the GPUtest running for more than 8 Hours.
if you ran the GPUtest for 4 hour the application works fine and at the end generate the result file.
if you put more than 8 hours of duration the GPUtest never end and never put the result files.
maybe is a Type Size issue and using more time we get an overflow.
I hope someone can fix this issue.
Regards
-Macs
Thanks for this feedback. I did long long tests (more than 100 hours!) on Windows several months ago and it worked fine. But I never did long stress test on OSX. I'll try to do that test for the next release...
