Author Topic: Cant start GLSL Hacker 0.7.0.3  (Read 13051 times)
gumlym
« on: September 03, 2014, 10:42:35 AM »
I cant seem to be able to start the program, and the weird thing is that the log doesnt show any error messages. Im trying to run it on a windows 8 laptop.
2014/9/3@10:29:27(0000000001) < > GLSL Hacker BETA v0.7.0.2 (Jul 23 2014@12:06:11)
2014/9/3@10:29:27(0000000002) < > Cross Platform Pixel Hacking Utility
2014/9/3@10:29:27(0000000003) < > (C)2012-2014 Geeks3D (www.geeks3d.com)
2014/9/3@10:29:27(0000000004) < > GLSL Hacker BETA is starting up...
2014/9/3@10:29:27(0000000005) < > platform: Windows 64-bit
2014/9/3@10:29:27(0000000006) < > OpenCL: OpenCL computing plugin (OpenCL 1.1, 1.2).. By JeGX / Geeks3D.com
2014/9/3@10:29:27(0000000007) < > Python27: Python 2.7 (64-bit) host api plugin for gxl engine. By JeGX / Geeks3D.com
2014/9/3@10:29:27(0000000008) < > [Python27] initializing Python 2.7 plugin...
2014/9/3@10:29:27(0000000009) < > [Python27] Python version: 2.7.6 (default, Nov 10 2013, 19:24:24) [MSC v.1500 64 bit (AMD64)]
2014/9/3@10:29:27(0000000010) < > [Python27] Python compiler: [MSC v.1500 64 bit (AMD64)]
2014/9/3@10:29:27(0000000011) < > [Python27] Python build info: default, Nov 10 2013, 19:24:24
Any ideas why this might be happening?
Re: Cant start GLSL Hacker 0.7.0.3
« Reply #1 on: September 05, 2014, 03:14:33 PM »
Probably an issue with the GPU monitor plugin.
Try to disable its loading by removing the plugin_gxl3d_gpu_monitor_gml_x64.dll from the plugins/ folder.
Let me know.
gumlym
« Reply #2 on: September 08, 2014, 09:42:45 AM »
I had already tried that, to no avail. It still doesnt start and the log contains the same message.
« Reply #3 on: September 08, 2014, 06:18:55 PM »
Maybe there is another plugin that perturbs GLSL Hacker startup. Have you tried to rename the plugins folder (that allows to disable all plugins)?
gumlym
« Reply #4 on: September 20, 2014, 12:06:07 PM »
Hi! (Sorry for the late reply) Yes that worked. I have then narrowed it down to this plugin: plugin_gxl_python_27_x64.dll If I remove that one from the plugins folder then it works :)
