GPU Test .7 Mac OSX 10.9.4 - Mac Mini - Intel HD3000 - Only shows a triangle
Started by tdehnke, July 19, 2014, 08:43:20 PM
tdehnke
Hi, I have a mac mini that I think has a GPU problem.
I've tried running 0.7 on osx 10.9.4 fresh install.
it only opens up a screen with a multicoloured triangle.
Any ideas on how to get it to run an actual stress test?
I think you launched GpuTest.app only.
GpuTest.app without command line params displays the simple triangle demo only.
Try to start the graphical user interface: GpuTest_GUI.app and let me know.
tdehnke
HI, I am running the GUI one first that brings up the drop down menu's options etc - when I click the run test button it then opens the app with the triangle.
You are correct, if I run just the app it goes directly to the triangle.  So the GUI is opening the test app, but either way once the test window is open it does not run the test as expected.
