Author Topic: Porting OpenGL Games to Android on Intel Atom Processors (part 1 of 2)  (Read 4716 times)
Porting OpenGL* Games to Android* on Intel® Atom™ Processors (part 1 of 2)
OpenGL expert Clay D. Montgomery takes you deep inside support for OpenGL ES on Android* devices, including tablets with Intel Inside®. He helps you decide whether to use the Android SDK or NDK when porting existing 3D PC games and applications to Android, and he explores the Java* Native Interface, which allows you to combine Java and C/C++ components.
