NVIDIA CUDA SDK 6.0 RC available to registered developers
Started by Stefan, February 19, 2014, 10:51:41 PM
QuoteDramatically simplify parallel programming with CUDA 6.0 .
Unified Memory
    Simplifies programming by enabling applications to access CPU and GPU memory without the need to manually copy data. Read more about unified memory.
Drop-in Libraries
    Automatically accelerate applications' BLAS and FFTW calculations by up to 8X by simply replacing the existing CPU libraries with the GPU-accelerated equivalents.
Multi-GPU scaling
    cublasXT - a new BLAS GPU library that automatically scales performance across up to eight GPUs in a single node, delivering over nine teraflops of double precision performance per node, and supporting larger workloads than ever before (up to 512GB). The re-designed FFT GPU library scales up to 2 GPUs in a single node, allowing larger transform sizes and higher throughput.
