NVIDIA Quadro driver 334.67 beta (vs. GPUCapsViewer)
Started by Stefan, January 26, 2014, 03:18:50 PM
FYI Desktop and notebook versions consist of the same packages.
Download
32bit
64bit
This driver is built against CUDA 6 and is incompatible with GPUCapsViewer 1.19 OpenCL GPU demos
(as opposed to driver 334.45 using CUDA 5.5)
QuoteNew in Release 334.67:
    This driver is from the most recent driver release branch, and contains the latest new features and functionality. It has been tested for workstation environments, and is recommended only for those users who need specific features mentioned in the release highlights or release notes.  Also known as the Quadro New Feature driver.
        For the most stable and fully supported enterprise driver please see the main Quadro download section.
    HD Audio Power Saving
        Added the ability for the audio codec to go to a low-power state when not in use.
    Quadro Sync Swapgroup Support
        Added support for swapgroups in full-screen OpenGL and Direct3D applications using Quadro Sync-capable Quadro cards. Windows 8
    NVENC
        Limited support to two simultaneous NVENC streamed sessions per GPU on low-end Quadro cards for unlicensed applications.
    Workstation application compatibility fixes. Please read the release notes for more information on product support, feature limitations, driver fixes and known compatibility issues.
