Notepad++ v6.5 released
Started by Stefan, September 29, 2013, 12:01:03 PM
QuoteNotepad++ v6.5 new features and bug fixes:
    Update Scintilla to 3.3.4
    Add CoffeeScript support.
    Add multi-paste support for multi-selection/column mode.
    Add new feature: auto-close parentheses, quotes, bracket and matched xml/html tag.
    Add php, perl, xml, batch, ini and nsis for the build-in function list.
    Add User Defined Languages support for the build-in function list.
    Add reload feature in function list.
    Fix a minor problem of file extension support for the build-in function list.
    Fix a tag matching bug by disabling tag matching inside PHP code blocks.
    Fix right-to-left text after closing document map bug.
    Fix cancelling shutdown make Notepad++ quit w/o saving files bug.
    Enhance "Begin/End select" feature: Check "Begin/End select" menu item when active.
    Enhance Mark all feature: 2 options "Match case" and "Match whole word only" in Find/Replace dialog.
    Fix a Replace dialog status bar display problem by clearing status bar before processing any action.
    Add new feature: if Notepad++ is running as administrator, display this info on the title bar.
    Rename "block comment" to "Single line comment" and "stream comment" to "block comment".
    Remove invalid command "Online Documentation".
