Author Topic: (Android) Unigine releases Oil Rush 3D for Qualcomm’s Snapdragon S4  (Read 6835 times)
A spectacular new mobile experience with Oil Rush 3D strategy game on your Android device
Oil Rush, an epic naval strategy game, is released for Android devices based on Qualcomm’s Snapdragon S4 chip. The game is already available on the Google Play Store and you can jump into the next-generation of 3D graphics, hardcore depth and touch-native controls directly on a mobile device. Oil Rush for Android is based on the proprietary multi-platform UNIGINE Engine and developed by UNIGINE Corp. Read more in the official press-release.
AndroidManifest.xml checks for GL_AMD_compressed_ATC_texture to make it Snapdragon exclusive.
psolord
Re: (Android) Unigine releases Oil Rush 3D for Qualcomm’s Snapdragon S4
« Reply #1 on: March 27, 2013, 07:22:16 PM »
So um, can you alter the manifest.xml so it does not check for that specific command and thus be compatible with other socs as well?
edit: meant does not check , sorry
« Last Edit: March 28, 2013, 01:54:38 PM by psolord »
« Reply #2 on: March 27, 2013, 08:17:10 PM »
you would need
7-zip or alternative
Android SDK
APKTOOL
ZIPsigner  or alternative
besides the manifest you need to check any other relevant file in the APK if ATI texture compression is actually used or not.
psolord
« Reply #3 on: March 28, 2013, 01:55:45 PM »
Sounds like a serious hack job, requiring skills of an advanced level, but still doable I believe.
Thanks.
ps I hate exclusives and proprietaries
