Author Topic: (Android/iOS) PassMark PerformanceTest 1.04  (Read 8019 times)
« on: February 07, 2013, 08:05:59 PM »
PassMark Software, the leader in PC benchmarks, now brings you benchmarks for mobile devices. Fast, easy to use, mobile device speed testing and benchmarking. PassMark PerformanceTestâ„¢ Mobile allows you to objectively benchmark a mobile device using a variety of different speed tests and compare the results to others.
*Find out if your device is performing at its best.
*Compare the performance of your device to similar devices online at http://www.mobilebenchmark.net.
*Measure the effect of configuration changes and upgrades.
*Make objective independent measurements on which to base your purchasing decision.
Seventeen standard benchmark tests are available in four test suites (with more to come...)
Test Suites:
*CPU Tests - Mathematical operations, compression, encryption and more
*Disk Tests - Reading and writing files to internal and external storage
*Memory Tests - Read and Write tests
*2D Graphics Tests - Simple & Complex Vectors and image rendering and filters tests
*3D Graphics Tests - Simple bouncing ball test and a more complex scene.
What's New in this version:
1. Bug fixes.
Simple 3D test is vsync limited  :P
