Author Topic: NVIDIA Tegra 3 ChromeOS driver 2012_04_17_09_58  (Read 3885 times)
« on: April 21, 2012, 03:37:59 AM »
Download binaries
Download codecs
Supported extensions:
EGL_KHR_config_attribs EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_ANDROID_blob_cache EGL_KHR_vg_parent_image EGL_NV_perfmon EGL_NV_system_time EGL_KHR_lock_surface EGL_KHR_fence_sync EGL_NV_sync EGL_NV_depth_nonlinear EGL_NV_post_sub_buffer EGL_NV_post_convert_rounding EGL_NV_native_query EGL_KHR_stream EGL_KHR_stream_fifo EGL_NV_stream_producer_eglsurface EGL_NV_stream_consumer_gltexture EGL_NV_stream_cross_process_fd EGL_NV_multiview_window EGL_EXT_create_context_robustness EGL_IMG_context_priority EGL_NV_3dvision_surface     EGL_NV_coverage_sample  EGL_NV_coverage_sample_resolve NVIDIA
GL_OES_rgb8_rgba8 GL_OES_EGL_sync GL_OES_fbo_render_mipmap GL_NV_depth_nonlinear GL_NV_draw_path GL_NV_texture_npot_2D_mipmap GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_vertex_half_float GL_OES_mapbuffer GL_NV_draw_buffers GL_NV_multiview_draw_buffers GL_EXT_Cg_shader GL_EXT_packed_float GL_OES_texture_half_float GL_EXT_texture_array GL_OES_compressed_ETC1_RGB8_texture GL_EXT_texture_compression_latc GL_NV_texture_compression_latc GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_NV_texture_compression_s3tc GL_EXT_texture_filter_anisotropic GL_NV_get_tex_image GL_NV_read_buffer GL_NV_shader_framebuffer_fetch GL_NV_copy_image GL_NV_fbo_color_attachments GL_EXT_bgra GL_EXT_texture_format_BGRA8888 GL_EXT_unpack_subimage GL_NV_pack_subimage GL_NV_texture_compression_s3tc_update GL_NV_read_depth GL_NV_read_stencil GL_NV_uniform_buffer_object GL_EXT_robustness GL_OES_standard_derivatives GL_NV_EGL_stream_consumer_external GL_NV_3dvision_settings GL_EXT_debug_marker GL_EXT_debug_label    GL_NV_coverage_sample   GL_EXT_occlusion_query_boolean  GL_NV_timer_query
