Author Topic: EVGA Precision X 3.02 with Android app  (Read 5947 times)
« on: April 10, 2012, 05:35:39 PM »
EVGA Precision X Version 3.0.2
Release: 4/10/12
    Added "Always on top" setting to the context menu of detached hardware monitor window. When this option is disabled, hardware monitoring window can be minimized to the taskbar when it is detached from the main window
    Added hardware monitoring history logging support. Now EVGA Precision is able to save history in native RivaTuner Hardware Monitoring Log file format. The log files captured with EVGA Precision can be viewed in any text editor like Notepad or in graphics form in RivaTuner's HML file viewer (RivaTuner must be installed for viewing log files in graphics form)
    Maximum framerate target increased to 120 FPS
    Maximum length of GPU name for GPU selection buttons has been increased to 10 symbols
    Added new "Force fan speed update on each period" option to the "Fan" tab. New option may improve compatibility of software automatic fan speed control mode with some bugged display drivers, overriding manually programmed fan speed under certain conditions
    Bundled EVGA EVTune utility has been replaced with brand new EVGA VoltageTuner utility
    Added bundled EVGA Bridge utility, allowing controlling EVGA Precision via Bluetooth from Android smartphones. The bridge utility is automatically started by EVGA Precision when "Enable external access to application via Bluetooth" is ticked in advanced settings
    Fixed issue in skin engine causing boost clock marker legend to be rendered improperly under certain conditions
    Added new "EVGA Classified" skin
EVGA Precision X APP
Introducing the next generation of GPU overclocking software: EVGA Precision X. Designed from the ground up to support the latest GPU technologies, EVGA Precision X redefines what overclocking software should be. This program allows you to fine tune your EVGA graphics card.*
*Requires a Bluetooth enabled PC and the latest version of precision
