NVIDIA Geforce/Verde driver 301.24 beta
Started by Stefan, April 09, 2012, 04:57:09 PM
This is the first unified driver from the R300 family of drivers (versions 300.00 to 301.99).
GeForce R300 drivers are packed with new industry-leading, GeForce-exclusive features as well as some really nice performance increases in top games.
New in R300 Drivers:
    New GPU Support – Adds support for the new GeForce GTX 680, the fastest, most efficient GPU ever built. Explore GeForce GTX 680 and its new SMX architecture on GeForce.com.
    Performance Boost – Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. GeForce 296.10 WHQL-certified drivers. Results will vary depending on your GPU and system configuration:
    GeForce GTX 570/580:
            Up to 23% in Just Cause 2 with SLI
            Up to 21% in The Elder Scrolls V: Skyrim
            Up to 17% in StarCraft II with SLI
            Up to 14% in Far Cry 2 with SLI
            Up to 9% in Bulletstorm
            Up to 7% in Civilization V
            Up to 6% in Deus Ex: Human Revolution with SLI
            Up to 6% in Dragon Age 2 with SLI
            Up to 5% in Metro 2033 with SLI
            Up to 5% in Total War: Shogun 2
    GeForce GTX 560/560 Ti:
            Up to 20% in The Elder Scrolls V: Skyrim
            Up to 15% in Just Cause 2 with SLI
            Up to 13% in Far Cry 2 with SLI
            Up to 12% in Bulletstorm
            Up to 11% in Civilization V
            Up to 10% in StarCraft II with SLI
            Up to 9% in Batman: Arkham City
            Up to 4% in Deus Ex: Human Revolution with SLI
            Up to 4% in Dragon Age 2 with SLI
            Up to 4% in Metro 2033 with SLI
            Up to 4% in Total War: Shogun 2
    NVIDIA FXAA Technology – shader-based anti-aliasing technology available from the NVIDIA Control Panel that enables ultra-fast anti-aliasing in hundreds of PC games. FXAA delivers similar quality to 4x multi-sample antialiasing (MSAA) but is up to 60% faster, enabling substantially higher performance in games. FXAA is supported on all GeForce 8-series and later GPUs. Note: This feature is disabled for games that already have built-in support for FXAA. Visit GeForce.com to learn more.
    NVIDIA Adaptive Vertical Sync – dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience. Adaptive VSync is supported on all GeForce 8-series and later GPUs. Visit GeForce.com to learn more.
    NVIDIA Frame Rate Target – dynamically adjusts frame rate to a user specified target. Support for this feature is enabled via third party applications via NVAPI. Visit GeForce.com to learn more.
    NVIDIA Surround Technology – Adds the following new Surround capabilities. Visit GeForce.com to learn more.
        Add in a fourth accessory display to get access to your email, web, or other applications while you game.
        Maximize an application to a single physical display when in Surround mode (enabled by default).
        Confine the Windows Taskbar to the center display (enabled by default).
        Enable bezel peeking – a feature which enables users to temporarily 'peak' behind the monitor bezels using a hotkey (Ctrl + Alt + B). This feature is designed to be used in conjunction with bezel corrected resolutions.
        Add or remove resolutions from the list of Surround resolutions (only those selected will be available to applications).
        Full center display acceleration for single wide display modes (center display must be connected to the master GPU).
    NVIDIA SLI Technology – Adds or updates the following SLI profiles:
        Alan Wake
        Call of Juarez: The Cartel
        Counter-Strike: Global Offensive
        Deus Ex: Human Revolution - The Missing Link
        Left 4 Dead
        Orcs Must Die!
        Portal 2
        Risen 2: Dark Waters
        The Darkness II
    NVIDIA 3D Vision – Adds or updates the following 3D Vision profiles:
        All Zombies Must Die! – rated Fair
        Ghosts 'n Goblins Online – rated Good
        Oil Rush – rated 3D Vision Ready
        Postal III – rated Good
        Rayman Origins – rated Good
        SevenCore – rated Fair
        Stacking – rated Good
        Unigine Heaven Benchmark v3.0 – rated 3D Vision Ready
        Wargame: European Escalation – rated Good
        Warp – rated Good
        Wings of Prey – rated Fair
        Krater – rated Poor
Other Details
    Installs PhysX System Software v9.12.0213.
    Installs HD Audio v1.3.12.0.
    Supports OpenGL 4.2
    Supports DisplayPort 1.2 for GeForce GTX 680.
    Supports multiple languages and APIs for GPU computing: CUDA C, CUDA C++, CUDA Fortran, OpenCL, DirectCompute, and Microsoft C++ AMP.
    Supports single GPU and NVIDIA SLI technology on DirectX 9, DirectX 10, DirectX 11, and OpenGL, including 3-way SLI, Quad SLI, and SLI support on SLI-certified Intel and AMD motherboards.
