Author Topic: (Android) Qualcomm Adreno200 OpenGL drivers for Ice Cream Sandwich  (Read 5848 times)
Mobile Gaming & Graphics Optimization (Adrenoâ„¢) Tools and Resources
Adreno 2xx User-mode Android ICS Graphics Driver (ARMv6)
This release contains the user-mode driver binaries for Qualcomm's Adreno 2xx GPU on Google Android Ice Cream Sandwich for ARMv6 based chipsets. It has been tested with the CAF release M8960AAAAANLYA1030. Supports any Adreno 2xx GPU on Android ICS using the ARMv6 chipset (7x27). Google's libRS (LLVM) does not currently support ARMv6.
Adreno 2xx User-mode Android ICS Graphics Driver (ARMv7)
This release contains the user-mode driver binaries for Qualcomm's Adreno 2xx GPU on Google Android Ice Cream Sandwich. It has been tested with the CAF release M8960AAAAANLYA1030. Supports any Adreno 2xx GPU on Android ICS.
This driver exposes a new EGL extension
EGL_QUALCOMM_shared_image
EGL_KHR_image
EGL_KHR_image_base
EGL_AMD_create_image
EGL_KHR_lock_surface
EGL_KHR_lock_surface2
EGL_KHR_fence_sync
EGL_IMG_context_priority
This driver exposes 3 new GL extensions, GL_QCOM_memory_monitor has been removed
GL_EXT_sRGB
GL_AMD_compressed_3DC_texture
GL_AMD_compressed_ATC_texture
GL_AMD_performance_monitor
GL_AMD_program_binary_Z400
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_format_BGRA8888
GL_EXT_texture_type_2_10_10_10_REV
GL_NV_fence
GL_OES_compressed_ETC1_RGB8_texture
GL_OES_depth_texture
GL_OES_depth24
GL_OES_EGL_image
GL_OES_EGL_image_external
GL_OES_element_index_uint
GL_OES_fbo_render_mipmap
GL_OES_fragment_precision_high
GL_OES_get_program_binary
GL_OES_packed_depth_stencil
GL_OES_rgb8_rgba8
GL_OES_standard_derivatives
GL_OES_texture_3D
GL_OES_texture_float
GL_OES_texture_half_float
GL_OES_texture_half_float_linear
GL_OES_texture_npot
GL_OES_vertex_half_float
GL_OES_vertex_type_10_10_10_2
GL_OES_vertex_array_object
GL_QCOM_alpha_test
GL_QCOM_binning_control
GL_QCOM_driver_control
GL_QCOM_perfmon_global_mode
GL_QCOM_extended_get
GL_QCOM_extended_get2
GL_QCOM_tiled_rendering
GL_QCOM_writeonly_rendering
This driver don't seem to work on Gingerbread  :-\
« Last Edit: March 30, 2012, 10:56:58 PM by Stefan »
