MSI Afterburner 2.2.0 Beta 12 (2012-02-02)
Started by Stefan, February 03, 2012, 04:25:10 PM
QuoteHi guys, today we have another update of MSI Afterburner 2.2.0 beta 12, do you guys find the Beta 11 already support HD 7950? If not, you can also use the Beta 12 to support HD 7950! There is another new GPU (5500+2270? lol) is supported by Afterburner 2.2.0 Beta 11/12, try to run it with Afterburner!
Changes list includes:
- Memory clock limit has been extended to 180% on AMD RADEON 79x0 graphics cards in unofficial overclocking mode
- Added low-level clock frequencies monitoring for AMD RADEON 79x0 graphics cards
- Added PowerTune adjustment slider for AMD HD 6xxx and 7xxx series graphics cards
- Improved overclocking profiles format provides compatibility with future graphics cards. Please take a note that existing overclocking profiles (startup overclocking profile and profile slots) will be ignored and must be recreated in new version
- MSI On-Screen Display server has been upgraded to v4.3.2. New version gives the following improvements:
o Added gamma corrected video capture support
o Framerate limit ratio for video capture in no longer controlled via the server's profiles. Now it can be adjusted directly into MSI Afterburner's video capture properties
o Added Direct3D9Ex support (DOTA 2 and Darkness 2 demo)
o Improved desktop windows notification mechanism eliminates unwanted beeps occurring on some systems during the server startup / shutdown
o Output video dimensions are now cropped to be multiple of 16 to improve compatibility with some third party MJPG decoders
o Improved OpenGL On-Screen Display coordinates calculation for framebuffer coordinate space mode
o Now "Enable compatibility with modified Direct3D runtime libraries" option is compatible with Direct3D9 game engines using double FPU precision (MassEffect series)
download link
[via]
