Author Topic: TechPowerUp ThrottleStop 4.0 / RealTemp 3.70  (Read 6070 times)
« on: January 16, 2012, 06:14:48 PM »
TechPowerUp Announces ThrottleStop 4.0
TechPowerUp also published the latest version of ThrottleStop, a nifty utility that lets you monitor the CPU clock speed throttling scheme used by your notebook, and provides you with options to override or change it. This is particularly useful for noteboook users facing performance issues even when the notebook is plugged in, despite enabling Windows "high-performance" power scheme. The application's main window lets you perform both monitoring and tweaking, its left pane provides you with tweaking your CPU's power scheme using three methods, while its right pane lets you monitor the way in which your OS is throttling the CPU, down to the level of logical CPUs (threads).
TechPowerUp Announces RealTemp 3.70
TechPowerUp today published the latest version of RealTemp, a comprehensive system processor temperature monitoring, logging, and clock speed monitoring utility. Version 3.70 packs several important updates over the previous version, starting with support for 6-core Intel "Sandy Bridge-E" processors, complete support for "Sandy Bridge" processors, more reliable power-consumption estimation using VID, updated i7 Turbo GT tool that lets you monitor multiplier changes with EIST and Turbo Boost playing tug-of-war, improved log file formatting, and visually-better max-temperature reporting through system-tray.
