Author Topic: Notepad++ 5.9.8 released  (Read 5228 times)
« on: January 05, 2012, 08:06:06 PM »
New features and fixed bugs in Notepad++ v5.9.8
- Add drag and drop capacity in Project Manager (only inside of Project Manager).
- Add "Move Up" (Ctrl+Up) and "Move Down" (Ctrl+Down) commands in Project Panel.
- Edit Zone border can be customizable via "Editing" tab of Preferences dialog.
- Fix an aesthetic problem in incremental search bar.
- Fix "Save all" GUI bug.
- Make plugins in %APPDATA%\Notepad++\plugins\ override les plugins in Notepad++ installation directory. (Plugins   loading from %APPDATA%\Notepad++\plugins\ is enabled only if NPP_INSTALLED_DIR\Notepad++\allowAppDataPlugins.xml is present)
Download: http://notepad-plus-plus.org/download/v5.9.8.html
