Author Topic: AMD GPU PerfStudio 2.8 released  (Read 5029 times)
« on: January 05, 2012, 05:16:11 PM »
GPU PerfStudio 2.8 Improvements
    New Properties Window added to display text based data
        The previous text based windows have been replaced by a single properties window
        The default stage layouts have been edited to use this new window
    Shader Debugger
        Constant table UI improvements
        More assembly shaders are now debuggable
        Fix for for the register mask of the last instruction being black
        The contents of the Shader constant table can now be saved to disk
    Shader Editor now supports relative paths
    Profiler
        The Profiler now gives the user feedback as the profile is taking place
        Single Draw Call Profiling is now supported
        Ability to perfrom a profile a specific number of times
        Support for 7000 series Performance Counters
        Reduced the memory overhead when many counters are used in a profile
    Advanced Picture Viewer
        Now saves to disk the image that you actually see (i.e. the channels the user selects)
        DDS Support for DXGI_FORMAT_R32_UINT
    Client connection dailog now saves settings upon connection
    OpenGL
        OpenGL 4.1 Compute Shader now supported
        Support for OpenGL debug context
