Author Topic: NVIDIA NVAPI Reference Documentation R290  (Read 6145 times)
« on: December 03, 2011, 07:24:18 PM »
NVAPI Release Notes
CHANGES IN NVAPI FOR DRIVER RELEASE 290
New Functions
? NvAPI_GPU_GetConnectedDisplayIds
? NvAPI_GPU_GetAllDisplayIds
? NvAPI_DISP_GetDisplayConfig
? NvAPI_DISP_SetDisplayConfig
New Structures
? NV_GPU_DISPLAYIDS
? NV_I2C_INFO_V2
? NV_TIMINGEXT
? NV_TIMING
? NV_DISPLAY_PATH_INFO - path array size modified
? NVVIOCAPS - Modified to represent the driver fields in 4 parts.
? NV_POSITION
? NV_RESOLUTION
? NV_DISPLAYCONFIG_PATH_ADVANCED_TARGET_INFO_V1
? NV_DISPLAYCONFIG_PATH_TARGET_INFO_V1
? NV_DISPLAYCONFIG_PATH_TARGET_INFO_V2
? NV_DISPLAYCONFIG_SOURCE_MODE_INFO_V1
? NV_DISPLAYCONFIG_PATH_INFO_V1
? NV_DISPLAYCONFIG_PATH_INFO_V2
New Enums
? NV_I2C_SPEED
? NV_TIMING_OVERRIDE
? NV_DISPLAYCONFIG_SPANNING_ORIENTATION
? NV_DISPLAYCONFIG_FLAGS
Deprecated NVAPI Functions
The following functions will be deprecated and replaced by new functions in coming
releases:
 Deprecated                                             Replaced By
 NvAPI_GetDisplayDriverVersion()                        NvAPI_SYS_GetDriverAndBranchVersion()
 NvAPI_GPU_GetAllOutputs()                              NvAPI_GPU_GetAllDisplayIds()
 NvAPI_GPU_GetConnectedOutputs()                        NvAPI_GPU_GetConnectedDisplayIds()
 NvAPI_GPU_GetConnectedSLIOutputs()                     NvAPI_GPU_GetConnectedDisplayIds()
 NvAPI_GPU_GetConnectedOutputsWithLidState()            NvAPI_GPU_GetConnectedDisplayIds()
 NvAPI_GPU_GetConnectedSLIOutputsWithLidState()         NvAPI_GPU_GetConnectedDisplayIds()
 NvAPI_SetView()                                        NvAPI_DISP_SetDisplayConfig()
 NvAPI_GetView()                                        NvAPI_DISP_GetDisplayConfig()
 NvAPI_SetViewEx()                                      NvAPI_DISP_SetDisplayConfig()
 NvAPI_GetViewEx()                                      NvAPI_DISP_GetDisplayConfig()
 NvAPI_VIO_SetCSC()                                     NvAPI_VIO_SetConfig()
 NvAPI_VIO_GetCSC()                                     NvAPI_VIO_GetConfig()
 NvAPI_VIO_SetGamma()                                   NvAPI_VIO_SetConfig()
 NvAPI_VIO_GetGamma()                                   NvAPI_VIO_GetConfig()
 NvAPI_VIO_SetSyncDelay()                               NvAPI_VIO_SetConfig()
 NvAPI_VIO_GetSyncDelay()                               NvAPI_VIO_GetConfig()
 NVAPIDriverSettings Changes
New additions:
? enum EValues_FXAA_INDICATOR_ENABLE
   SHIM_RENDERING_OPTIONS_ALLOW_CP_CAPS_FOR_VIDEO value added to
   EValues_SHIM_RENDERING_OPTIONS
? FXAA_INDICATOR_ENABLE_ID
? FXAA_INDICATOR_ENABLE_STRING
? SHIM_RENDERING_OPTIONS_ID
? SHIM_RENDERING_OPTIONS_STRING
