Author Topic: NVIDIA driver 270.61 WHQL  (Read 9286 times)
« on: April 18, 2011, 05:31:16 PM »
This is the first WHQL-certified release from the Release 270 family of drivers (versions 270.xx to 274.xx). You can read more about this family of drivers on GeForce.com.
Geforce/ION driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, 400, and 500-series desktop GPUs as well as ION desktop GPUs.
New in Release 270.61
GPU Support
    Adds support for the newly released GeForce GTX 590, GeForce GTX 560 Ti and GeForce GTX 550 Ti GPUs.
Verde driver supports the following NVIDIA notebook GPUs (please refer to the Products Supported tab for exceptions):
    ION notebook GPUs.
    GeForce 8M, 9M, 100M, 200M, 300M, 400M, and 500M-series notebook GPUs.
    Quadro 5000M, 2000M and 1000M notebook GPUs.
    Quadro NVS-series notebook GPUs (only those that support DirectX 10 or higher).
    Quadro FX-series notebook GPUs (only those that support DirectX 10 or higher).
This driver package also includes the 3D Vision Controller driver.
GPU Support
    Adds support for the newly released GeForce GT 555M, GeForce GT 550M, GeForce GT 540M, GeForce GT 525M, and GeForce GT 520M GPUs.
Performance
    Increases performance for GeForce 400 Series and 500 Series GPUs in several PC games vs. v266.58 WHQL drivers.
Downloads at NVIDIA
« Last Edit: April 18, 2011, 05:35:46 PM by Stefan »
shanto154
Re: NVIDIA driver 270.61 WHQL
« Reply #1 on: April 19, 2011, 10:45:17 PM »
Hi
Can you help and do this for us?
Type dispdiag on the commandline (dispdiag is a tool that should be installed on your operating system).
This should create a file called "DispDiag-<timestamp>.dat".
Please then attach that to the forums or send me a PM and you can email it to me.
Need help with 3D Vision or 3DTV Play? Find what you need quickly.
    3D Vision General Information
    3D Vision System Requirements.
    3D Vision Game Support
    3D Vision FAQs
    3DTV Play Homepage
    3DTV Play System Requirements and Supported 3D TVs
    TV Not Supported? Click here
    3DTV Play 14 day trial
    3DTV Play FAQs
thank you
shanto154
« Reply #2 on: April 21, 2011, 05:22:41 PM »
The tool that you mean is actually called DXDIAG
Which information precisely do you need (to compare to your broken system i assume)?
