AMD OpenCL Emu Documentation
Started by Stefan, March 28, 2011, 06:06:04 PM
QuoteOpenCL Emu is a set of effective tools for the OpenCL software development designed for AMD GPUs
without the explicit need of GPU hardware. It allows developing and debugging an OpenCL kernel as a
C++ procedure inside your MS Visual Studio application while providing an easy switch between CPU,
GPU or GPU-emulator at the backend.
This tool would enable programmers to start developing using OpenCL language instantly without having
to learn the intricacies of the OpenCL run-time, saving them time to concentrate more on developing
parallel algorithms and making the shift to OpenCL a step easier.
