Author Topic: AMD Catalyst 11.1a Tessellation Hotfix  (Read 10025 times)
« on: January 19, 2011, 12:16:56 AM »
The latest Catalyst Hot-Fix; (11.1a) offers increased performance brings a slew of new features and should be the driver used for any performance testing. Below are a few of the highlights from this driver:
Performance improvements for the AMD Radeon HD 6800 & HD 6900 series include but not limited to:
AMD Radeon HD 6900 and AMD Radeon HD 6800 Series:
    * 3DMark Vantage improves ~7%
    * 3DMark06 improves ~3%
    * Call of Duty Black Ops improves ~20% at 4xMSAA and up to 35% at 8xMSAA
    * Riddick Assault on Dark Athena SSAO performance improves ~20%
    * Unigine Heaven OpenGL performance improves ~10% at moderate, 30% at normal and 100% at extreme tessellation levels
    * Aliens vs. Predators improves ~9% at 2xMSAA and up to 20% at 4xMSAA
    * Batman Arkham Asylum improves ~4%
    * Crysis Warhead improves ~2-4%
    * Metro 2033 improves ~28% at 4xMSAA
AMD Radeon HD 6900 Series:
    * Battleforge DirectX 11 performance improves as much as 6%
New Tessellation Controls:
    * The Catalyst Control Center includes an  early prototype of some new tessellation controls.   Our goal is to give users full control over the tessellation levels used in applications.   The default selection “AMD Optimized” setting allows AMD, on a per application basis, to set the best level of tessellation.   The intention is to help users get the maximum visual benefit of Tessellation, while minimizing the impact on performance.  Currently no applications have been profiled, so the “AMD Optimized” setting will be non-operational until further notice.
    * The “Use Application Settings” option gives applications full control over the Tessellation level. Users can also manually set the maximum tessellation level used by applications with the slider control
    * The long term goal for the “AMD Optimized” setting is to use the Catalyst Application Profile mechanism to control the AMD recommended level of tessellation on a per application basis.  AMD’s intention is to set the tessellation level such that we will not be reducing image quality in any way that would negatively impact the gaming experience.
"Wrestler" is now really the codename for Vancouver GPUs
OpenGL 4.1.10428 exposes a new  extension: GL_AMD_shader_trace
GL_MAX_VARYING_FLOATS doubled from 64 to 128
CAL updated to rev. 1016, but no new OpenCL extensions
Apparently i suck at Mobility modding: result OpenGL tessellation factor = ZERO  ;D
Re: AMD Catalyst 11.1a Tessellation Hotfix
« Reply #1 on: January 19, 2011, 04:29:28 PM »
Phew! Actually AMD developers themselves screwed the drivers.
I replaced OpenGL runtimes with those from "Cat11.1 Vancouver 8.810"
These contain the new extensions, however i saw no changes to tessellation with my Cedar laptop.
http://www.filefront.com/17815054/opengl10428.7z/
atio6axx.dll = 64 bit
atioglxx.dll = 32 bit
