Author Topic: CUDA Toolkit and SDK 2.3 betas available to registered developers  (Read 10680 times)
The CUDA Toolkit and SDK 2.3 betas are now available to registered developers. They include the following features:
    * The CUFFT Library now supports double-precision transforms and includes significant performance improvements for single-precision transforms as well. See the CUDA Toolkit release notes for details.
    * The CUDA-GDB hardware debugger is now available for all supported Linux platforms and is included in the CUDA Toolkit installer.
    * GPUs in an SLI group are now enumerated individually, so you can achieve multi-GPU performance even when SLI is enabled for graphics.
    * New support for fp16 <-> conversion intrinsics allows storage of data in fp16 format with computation in fp32. Use of fp16 format is ideal for applications that require higher numerical range than 16-bit integer but less precision than fp32 and reduces memory space and bandwidth consumption.
    * The CUDA SDK has been updated to include:
          o A new pitchLinearTexure code sample that shows how to effeciently texture from pitch linear memory.
          o A new PTXJIT code sample illustrating how to use cuModuleLoadDataEx() to load PTX source from memory instead of loading a file.
          o Two new code samples for Windows, showing how to use the NVCUVID library to decode MPEG-2, VC-1, and H.264 content and pass frames to OpenGL or Direct3D for display.
          o Updated code samples showing how to properly align CUDA kernel function parameters so the same code works on both x32 and x64 systems.
    * The Visual Profiler (packaged separately) includes several enhancements:
          o All memory transfer API calls are now reported
          o Support for profiling multiple contexts per GPU.
          o Synchronized clocks for requested start time on the CPU and start/end times on the GPU for all kernel launches and memory transfers.
          o Global memory load and store efficiency metrics for GPUs with compute capability 1.2 and higher.
    * The CUDA Driver for MacOS is now packaged separately from the CUDA Toolkit.
    * Support for major Linux distros, MacOS X, and Windows:
          o Fedora 10, RHEL 4.7 & 5.3, SLED 10.2 & 11.0, OpenSUSE 11.1, and Ubuntu 8.10 & 9.04
          o Windows XP/Vista/7 with Visual Studio 8 (VC2005) and 9 (VC2008)
          o MacOS X 10.5.6 and later (32-bit)
