Author Topic: GLC Player 2.2.0 with Windows 64 bit support  (Read 5731 times)
« on: July 04, 2010, 08:26:01 AM »
GLC_Player 2.2.0
List of the new functionalities:
    * Use visualization partitioning and frustum culling to enhance graphic performance on heavy 3D Scene.
    * Add the possibility to edit "Pixel Culling" size.
    * Add the new fly navigation mode.
    * Add interactive sectioning possibility (OpenGL clipping plane).
    * Add the possibility to save all supported format in the open (Dassault Systemes 3DXML V4 format).
    * Add the possibility to use parallel or perspective projection.
    * Add the possibility to use 4 OpenGL lights and to edit their position.
    * Display the number of renderer geometries and triangles.
    * Add the possibility to display 3DXML edges.
    * Add Windows 64 bits distribution.
List of enhancements :
    * Better 3DXML and Collada file format support.
    * Reduce OBJ file loading time.
    * Use OpenGL multi-samples for anti-aliasing
