Author Topic: Total Commander 7.55 FINAL for Windows released  (Read 4932 times)
« on: June 18, 2010, 05:53:07 AM »
Total Commander 7.55 is now available for download. The most important new functions are:
    * Use MLSD command for file listings in FTP function (better time resolution, time in UTC)
    * Transfer files between two computers over a special USB cable -> supported cables
    * Improvements to synchronize dirs function: Compare via plugins and FTP, options to skip hidden files and hard links, SITE UTIME in ftp sync
    * Compare by content now shows different and changed lines with a slightly different background color (configurable via wincmd.ini)
    * Unpack directory time stamps from archives
    * Lister: Increased maximum line length to 1024 characters (Unicode: 512)
    * Verify CRC checksums: Also support CRC files in UTF16 Unicode format
    * Show Terminal Server and Win7 XP mode drives in drive dropdown list and drive buttonbar
    * Ctrl+Shift+B and cm_DirBranchSel shows branch view of only the selected dirs+files
    * F5 copy dialog: "Options" dialog extension can be pinned now to remain open
    * Show progress dialog box when reading a directory takes longer than 5 seconds
    * Create CRC checksums: support subdirectories (recursively), background button
    * Handle dir space calculation in background (when user presses SPACE or Alt+Shift+Enter)
    * File system plugins: Support background downloads and uploads (requires changes to plugin)
    * Various new background operations: Unpack: RAR, TAR, packer plugins (needs modification), Pack: TAR, packer plugins
