Custom MESA & SwiftShader Windows drivers
Started by Stefan, May 23, 2024, 07:35:49 PM
0 Members and 3 Guests are viewing this topic.
Updates:
zink/DZN - Vulkan-Headers 1.3.293
Vulkan-Loader 1.3.292
Terakan
  • 133875fa ยท terakan: WIP: Fragment shader unordered access views
Updates:
zink/DZN - Vulkan-Headers 1.3.299 + MESA 25.0git
Vulkan-Loader 1.3.301
Updates:
zink/DZN - Vulkan-Headers 1.4.304
Vulkan-Loader 1.4.304
SwiftShader 5221bf0 Implement VK_EXT_index_type_uint8
NB
Albeit the source code claims "Vulkan 1.4 promoted extensions", Google devs did not update the Vulkan API yet.
I'm stuck at 1.3.288, later versions require major SPIR-V changes.
Updates:
zink/DZN - Vulkan-Headers 1.4.306 (issues only)
Vulkan-Loader 1.4.306
SwiftShader
fc53776 Support VK_GOOGLE_surfaceless_query
// Used by ANGLE to properly advertise the supported list of EGL configs.
NB
skipped commit c619fa4 which broke building on my rig (975 errors!)
Update
MESA 25.1-devel
adds a new OpenGL extension: zink: KHR_shader_subgroup
zink/DZN - Vulkan-Headers 1.4.310
Vulkan-Loader 1.4.310
SwiftShader
2407a54 Fix LLVM's AlignOf after previous change to support c++23
fixes aforementioned build issue
Quotegitlab.freedesktop.org will be unavailable for up to a week starting March 16th, due to our ongoing infrastructure move. You can follow our planning tracker at https://gitlab.freedesktop.org/freedesktop/freedesktop/-/issues/2076
