furmark stuttering
Started by tom55, August 18, 2024, 10:42:02 PM
tom55
i'm running amernime driver on win10 laptop - bristol ridge APU with RX460 GPU
if i choose MS FIXED RENDER config setting in amernime toolbox then everything is fine
to make use of improved RX460 driver i need to choose MS FIXED HYBRID config option, then the FPS counter seems ok, but the output image is stuttering
with the same config valley benchmark is running fine in openGL mode as well as gfxbench which shows improved scores
is there a change needed to furmark to fix this or it is a possible driver regression ? i used versions 1.21 and 1.37
tom55
it was a driver bug. with 23.4.1 driver it works as expected
