are furmark 1 FPS correct?
Started by tom55, September 26, 2024, 03:21:54 AM
tom55
tested the difference of improved amd opengl driver, two other benchmark tools show performance increase, for example 22FPS with old driver and 30FPS with new driver
with furmark scores are similar with both drivers, it doesn't tell there is a difference.
also checked presenter setting in latest hwinfo releases, when furmark is giving a 33FPS in FHD test, hwinfo reports about 10-15FPS more. on resolutions lower than 1600x900 both report the same FPS
