FurMark 2.3 released
Started by JeGX, May 06, 2024, 06:54:09 PM
0 Members and 3 Guests are viewing this topic.
FurMark 2.3.0 has been released for Windows 32/64-bit, Linux 64-bit and Raspberry Pi OS arm64.
Release notes:
https://geeks3d.com/20240506/furmark-2-3-released/
Homepage:
https://www.geeks3d.com/furmark/
All downloads:
https://www.geeks3d.com/furmark/downloads/
Quoteversion 2.3.0.0 - 2024.05.03
- added Raspberry Pi 64-bit (arm64 / aarch64) support.
- added fan speed in the GPU monitoring section.
- fixed graphics bug (horizontal line) in the background of the FurMark(GL) demo.
- artifact scanning: window resizing is now disabled.
- fixed GPU usage monitoring of Intel Arc GPUs.
- GPU monitoring in the GUI is now done in a separate thread.
- updated with GPU Shark2 2.3.0.0
- updated with GPU-Z 2.59
- updated with GeeXLab 0.59.0 libs
yeakyau88
I notice that version furmark 2.3 released unable to benchmark intel arc gpu using vulkan may I know is there any bugs or it's totally not supported?
Quote from: yeakyau88 on May 21, 2024, 03:26:32 AMI notice that version furmark 2.3 released unable to benchmark intel arc gpu using vulkan may I know is there any bugs or it's totally not supported?
There are successful Intel ARC using Vulkan submissions
https://gpumagick.com/scores/?benchmarkid=110&sorting=0&vendorid=32902&gpuid=0&preset=0
What does GPUShark 2 read on Vulkan tab? Screenshot please.
We need more information! How did you notice? Links?
I have an Arc GPU and Vulkan tests of FurMark 2.3 work perfectly with the A750.
yeakyau88
#4
Quote from: JeGX on May 22, 2024, 03:33:17 PMWe need more information! How did you notice? Links?
It's also happen on MSI KOMBUSTER version 4.1.29.
Tested Pentium 5420, i9-9900K
Intel Arc GPU model:  A310,A380,A580
Below images for your reference:
Only MSI Kombuster version 4.1.3.0 able to benchmark using vulkan for intel arc A310,A380,A580
Sorry is here the right place to report MSI Kombuster as well?
Thanks.
Thanks for your screenshots.
Yes you can post feedback here about Kombustor.
I have to improve the GPU monitoring a bit...
You have 3 discrete GPUs (A310, A380 and A580) and one integrated  (UHD 610). Can you confirm that?
I will do a test with an Arc A750 + Arc A380. I hope to see the crash!
And what is the driver version?
yeakyau88
#6
Dear JeGx,
sorry for late reply
QuoteYou have 3 discrete GPUs (A310, A380 and A580) and one integrated  (UHD 610). Can you confirm that?
Yes you are right
asus  10th Gen motherboard also facing same issues
Intel Arc Driver version 31.0.101.5382
Intel chipset version 10.1194444.8378
FYI,
I tested on Adlink 13th /14th Gen Motherboard without having any problem with kombuster 4.1.29  .
But it's not able to benchmark using kombuster 4.1.29   on 9th gen and 10th gen motherboard, i found out only kombuster  4.1.3.0 version (64bit) able to benchmark only.
Remark: I plugged in 2 ubut led monitor, 1unit plugged in IGPU(motherboard display port or hdmi port), the other unit plugged in intel arch graphic cards will cause not responding then unable to benchmark.
Solutions: I plugged 2 led monitors on igpu ( motherboard display port and hdmi port and without plugged into intel arc graphic cards then its only work. (This method only work on intel chipset Q370 IEI motherboard).
However for Asus Q470  intel chipset  still have the crashed, even plugged in one monitor still unable to benchmark. the only solutions using kombustor
version 4.1.3.0 to do benchmark.
May I know why it's only happen on intel arc? But for nvidia graphic cards are ok without have any issues even I plugged in one unit led monitor on IGPU and the other unit monitor on nvidia graphic card.Im still able to benchmark without crashed( not responding then exit) the kombustor software
Thanks,
