Author Topic: Media Coder 0.7.1 - free CUDA accelerated audio & video converter  (Read 51398 times)
Features in Brief
    * Convert between many audio and video compression formats and re-multiplex into various container formats, on the fly or in batches
    * Complete control over the transcoding process and all of the chosen parameters of your converted file, so you can learn about, compare among and play with various codecs
    * A flexible device plug-in infrastructure brings specific interfaces for specific devices
    * Fully standalone, no need to install a separate media player, filters or codecs, and no requirement to register components into your system
    * Extensions to expand custom features and user interfaces
Typical Applications
    * Improving compression / reducing file size
    * Converting for audio/video portable devices (digital audio player, MP4 player, mobile phone, PDA, PSP, VCD/DVD player etc.)
    * Extracting audio tracks from video files
    * Ripping audio/video discs CD/VCD/DVD
Supported Audio & Video Formats
    * MP3, Vorbis, AAC, HE-AAC, HE-AAC v2, MusePack, Speex, Windows Media Audio, AMR NB/WB, RealAudio, mp3PRO*
    * FLAC, WavPack, Monkey's Audio (APE), OptimFrog, Audio Lossless Coding (ALS), WMA Lossless*, True Audio (TTA)*, WAV
    * H.264, Xvid, MPEG 1/2/4, Theora, Flash Video, Dirac, H.263, 3ivx*, RealVideo*, Windows Media Video (WMV)
    * AVI, MPEG/VOB, Matroska, MP4, ASF, RealMedia*, QuickTime/MOV*, OGM*
    * CD, VCD, DVD, Cue sheet
Get it from MediaCoderHQ.
niceemily
Re: Media Coder 0.7.1 - free CUDA accelerated audio & video converter
« Reply #1 on: March 30, 2011, 09:04:38 AM »
thanks for sharing this useful info
but i like the following CUDA based Video Converter called Bigasoft Total Video Converter
reason 1 Optimized by NVIDIA® CUDA computing technology, Bigasoft Total Video Converter accelerates conversion to revolutionary fast. Converting video now is in minutes.
reason 2 it can achieve video conversion between a wide range of video formats, including AVI, Xvid, DivX, H.264, MP4, 3GP, MKV, WMV, RM, FLV, MOV, WebM, VP8, 720p, 1080p, 1080i HD, AVCHD videos and more.
reason 3 it can  also  convert between audio files like MP3, AAC, AC3, WAV, WMA, etc. Moreover, it can extract audio from video and music video by only a few clicks.
reason 4 it  is equipped with advanced editing function. It enables to adjust audio volume, rotate video, add audio track and subtitle for video, increase artistic effects for video, add image or text watermark for video, split video, merge videos into one, trim and crop video, capture preferable picture from video and more.
Windows version at http://www.bigasoft.com/total-video-converter.html?xgeek
Mac version at http://www.bigasoft.com/total-video-converter-mac.html?xgeek
« Last Edit: May 05, 2011, 04:08:20 AM by niceemily »
luckyemily
« Reply #2 on: September 08, 2011, 09:22:03 AM »
i wonder is there some really free way to do that
happygirlbaby
« Reply #3 on: July 11, 2012, 10:48:52 AM »
anyway, it is worth to pay for it, for it is so powerful and it can convert between almost all popular video formats
