Author Topic: AMD Radeon Software Adrenalin Edition 18.9.1  (Read 839 times)
« on: September 13, 2018, 12:59:36 AM »
Radeon Software Adrenalin Edition 18.9.1 Highlights
 Support For
  • Shadow of the Tomb Raider™
  • Star Control®: Origins
Fixed Issues
  • Radeon FreeSync may fail to enable when playing Monster Hunter™: World.
  • Radeon Settings may sometimes not appear in the right-click context menu on Windows® desktop after Radeon Software installation.
  • AMD Link may fail to connect on Android Pie devices due to authentication failures.
  • Radeon Settings may sometimes popup an error message due to Driver and Radeon Settings version mismatch.
  • Cursor or system lag may be observed on some system configurations when two or more displays are connected and one display is powered off.
  • Some DirectX®12 gaming applications may experience instability while recording with Radeon ReLive on system configurations using Radeon R9 290 and Radeon R9 390 series graphics products.
AMD Radeon Software Adrenalin Edition 18.9.1 - GL and VK details
« Reply #1 on: September 13, 2018, 08:41:55 AM »
Adrenalin 18.9.1 for a Radeon RX Vega 56 on Win10 64-bit:
- same GL and VK support than 18.8.1
- OpenGL 4.6 (4.6.13539 Compatibility Profile/Debug Context 24.20.13017.1009) with 324 extensions (GL=299 and WGL=25)
- Vulkan 1.1.77
