Author Topic: NVIDIA GeForce driver 390.48 for Linux, FreeBSD and Solaris  (Read 1347 times)
« on: March 28, 2018, 06:36:46 PM »
  • Added support for the following GPUs:
    • Quadro GV100
  • Updated the driver to prevent G-SYNC from being enabled when a Quadro Sync board is installed. G-SYNC and Quadro Sync were always mutually incompatible features, and this change makes it easier to use G-SYNC capable monitors on Quadro Sync configurations, as it is now no longer necessary to manually disable G-SYNC.
  • Further improved the fix for occasional flicker when using the X driver's composition pipeline.  This was mostly fixed in 390.42, but now the fix should be more complete.
  • Improved compatibility with recent Linux kernels.
  • Fixed a string concatenation bug that caused libGL to accidentally try to create the directory "$HOME.nv" rather than "$HOME/.nv" in some cases where /tmp isn't accessible.
  • Increased the version numbers of the GLVND libGL, libGLESv1_CM, libGLESv2, and libEGL libraries, to prevent concurrently installed non-GLVND libraries from taking precedence in the dynamic linker cache.
  • Fixed a bug which could cause X servers that export a Video Driver ABI earlier than 0.8 to crash when running X11 applications which call XRenderAddTraps().
  http://de.download.nvidia.com/XFree86/Linux-x86_64/390.48/NVIDIA-Linux-x86_64-390.48.run
 http://it.download.nvidia.com/XFree86/Linux-x86/390.48/NVIDIA-Linux-x86-390.48.run
 http://us.download.nvidia.com/XFree86/FreeBSD-x86_64/390.48/NVIDIA-FreeBSD-x86_64-390.48.tar.gz
 http://fr.download.nvidia.com/solaris/390.48/NVIDIA-Solaris-x86-390.48.run
 http://cn.download.nvidia.com/XFree86/Linux-x86-ARM/390.48/NVIDIA-Linux-armv7l-gnueabihf-390.48.run
 http://jp.download.nvidia.com/XFree86/FreeBSD-x86/390.48/NVIDIA-FreeBSD-x86-390.48.tar.gz
