Author Topic: DirectX Raytracing Tutorials  (Read 1352 times)
« on: March 20, 2018, 07:36:01 AM »
This repository contain tutorials demonstrating how to use DirectX Raytracing. Under the Tutorials folder you can find Word documents going over the code, explaining how to use the API.
Requirements:
  • Windows 10 RS4. Follow the instructions on the DirectX forums.
  • Windows 10 SDK 10.0.16299.91.
  • Visual Studio 2015.
  • You do not need to download the DXR SDK, it is packaged with the tutorials.
  • Open the solution, build it, knock yourself out.
Unsurprisingly the samples don't run on Redstone 3 (missing procedure entry points in runtimes)-
I'll recheck next month with Redstone 4.
