Author Topic: NVIDIA OptiX 5.0.0  (Read 1447 times)
NVIDIA OptiX 5.0.0
« on: December 27, 2017, 06:28:39 AM »
Release Highlights NVIDIA® OptiX™ 5.0 (Dec 2017)
Welcome to the first OptiX 5 SDK release. This version is an important milestone in the evolution of OptiX, featuring built-in support for motion blur, and a deep-learning based denoiser. Version 5.0 maintains compatibility with your existing applications and provides the same easy to use API for which OptiX is known.
 Improvements to 5.0
  • New AI-Accelerated Denoiser
  • Support for Volta class GPUs has been added.
  • Support for motion blur by enabling motion data for Transform and Geometry nodes
  • Improved startup time and general performance improvements
  • Two new samples demonstrate how the NVIDIA Material Definition Language (MDL) can be used with OptiX
