Author Topic: GPU Caps Viewer 1.37.0 released  (Read 5431 times)
« on: October 31, 2017, 01:35:11 PM »
GPU Caps Viewer 1.3.7.0.0 is available.
Release highlights and downloads:
http://www.geeks3d.com/20171031/gpu-caps-viewer-1-37-0-released/
PeterYS
Re: GPU Caps Viewer 1.37.0 released
« Reply #1 on: January 03, 2018, 11:08:25 AM »
Hi sir,
I had a problem need help.
When I run GPU Caps Viewer 1.37.0 - 3D Demos - OpenCL CPU - 4D Quaternion Julia Set, it will popup "OpenCL CPU not supported on the selected platform", why tool show that? that mean my CPU is not support?
My fail system is Notebook, Intel CPU + NV GPU, and i check OpenCL page, Device only show Number of CL deivces:1.
But another system Intel + AMD is pass, and OpenCL page is show devices:2, and i can found CPU information.
May i know which behavior is correct? and why other is incorrect? how can i fix it?
« Reply #2 on: January 03, 2018, 08:00:38 PM »
CPU OpenCL demos are supported by AMD and Intel only. NVIDIA does not provide CPU OpenCL and supports only GPU OpenCL.  You can try to install the AMD OpenCL SDK on you system to get software OpenCL.
Israeli
« Reply #3 on: January 12, 2018, 11:02:22 PM »
Since Nvidia 390.65 not work anymore, only crash.  >:(
But I saw in a pic that 1.37.1.0 was used, but where I can get and download it?
« Reply #4 on: January 14, 2018, 10:51:45 AM »
Is there something in the log file? Could you please post it?
The v1.37.1 will be soon released.
upapi_geeks
More GPU Ino... not starting due to 0xc0000005 error
« Reply #5 on: January 14, 2018, 04:40:39 PM »
I'm using the newest portable GPU Caps Viewer on Windows 10 64 Bit (newest Version) on different PC's and LapTops with different graphic Cards.
When I click the button More GPU Info.. I receive on every System the error .. gpushark.exe cannot be started correctly (0xc0000005)...
How can I solve this Problem? No other Problems on all Systems no AV System only Defender and no Tuning apps.
Log:
16:29:29 | 0 >> GPU Caps Viewer 1.37.0.0 startup...
16:29:29 | 1 >> [SGX] - SGX 0.3.0.0 initialization in progress...
16:29:29 | 2 >> [SGX] - (C)2015-2017 Geeks3D - www.geeks3d.com/geexlab/
16:29:29 | 3 >> [SGX] - Plugin search path: E:\GPU_Caps_Viewer\plugins/
16:29:29 | 4 >> [SGX] - SGX initialized OK.
16:29:29 | 5 >> [SGX] - Plugin search path: E:\GPU_Caps_Viewer\gxcplugins/
16:29:29 | 6 >> [SGX] - [Plugin manager] unable to load the plugin: E:\GPU_Caps_Viewer\plugins/plugin_gxc_gpumon_x32.dll
16:29:29 | 7 >> [SGX] - [GpuMonitor] GPU monitoring plugin for NVIDIA and AMD GPUs
16:29:29 | 8 >> [SGX] - [GpuMonitor] Operating system detected: Windows 10 build 16299
16:29:29 | 9 >> [SGX] - [GpuMonitor] Num GPUs found: 1
16:29:29 | 10 >> [SGX] - [GpuMonitor] GPU0 - GeForce GTX 745
16:29:29 | 11 >> [SGX] - [GpuMonitor] GPU0 - PCI codes: 0x10DE-0x1382
16:29:29 | 12 >> [SGX] - [GpuMonitor] GPU0 - BIOS: 82.07.25.00.b3
16:29:29 | 13 >> [SGX] - [GpuMonitor] GPU0 - core temperature: 34 degC
16:29:29 | 14 >> [SGX] - [GpuMonitor] GPU0 - driver: R390.65
16:29:29 | 15 >> [SGX] - Plugin plugin_gxc_gpumon_x32.dll successfully loaded
16:29:29 | 16 >> - DEV 0 - DeviceID: PCI\VEN_10DE&DEV_1382&SUBSYS_31101462&REV_A2
16:29:29 | 17 >> - DEV 0 - DeviceName: \\.\DISPLAY4
16:29:29 | 18 >> - DEV 0 - DeviceString: NVIDIA GeForce GTX 745
16:29:29 | 19 >> - DEV 0 - DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Video\{C0B98B70-F938-11E7-AF54-C03896253D5F}\0000
16:29:29 | 20 >> - DEV 1 - DeviceID: PCI\VEN_10DE&DEV_1382&SUBSYS_31101462&REV_A2
16:29:29 | 21 >> - DEV 1 - DeviceName: \\.\DISPLAY5
16:29:29 | 22 >> - DEV 1 - DeviceString: NVIDIA GeForce GTX 745
16:29:29 | 23 >> - DEV 1 - DeviceKey: \Registry\Machine\System\CurrentControlSet\Control\Video\{C0B98B70-F938-11E7-AF54-C03896253D5F}\0001
16:29:29 | 24 >> Found 1 OpenCL-capable platform.
16:29:29 | 25 >> Found 1 OpenCL-capable devices for platform NVIDIA CUDA.
16:29:29 | 26 >> Vulkan - instance extensions: 11
16:29:29 | 27 >> Vulkan - 1/ VK_EXT_debug_report (spec version: 9)
16:29:29 | 28 >> Vulkan - 2/ VK_EXT_display_surface_counter (spec version: 1)
16:29:29 | 29 >> Vulkan - 3/ VK_KHR_get_physical_device_properties2 (spec version: 1)
16:29:29 | 30 >> Vulkan - 4/ VK_KHR_get_surface_capabilities2 (spec version: 1)
16:29:29 | 31 >> Vulkan - 5/ VK_KHR_surface (spec version: 25)
16:29:29 | 32 >> Vulkan - 6/ VK_KHR_win32_surface (spec version: 6)
16:29:29 | 33 >> Vulkan - 7/ VK_KHX_device_group_creation (spec version: 1)
16:29:29 | 34 >> Vulkan - 8/ VK_KHR_external_fence_capabilities (spec version: 1)
16:29:29 | 35 >> Vulkan - 9/ VK_KHR_external_memory_capabilities (spec version: 1)
16:29:29 | 36 >> Vulkan - 10/ VK_KHR_external_semaphore_capabilities (spec version: 1)
16:29:29 | 37 >> Vulkan - 11/ VK_NV_external_memory_capabilities (spec version: 1)
16:29:29 | 38 >> Vulkan - # devices: 1
16:29:29 | 39 >> Vulkan - [ Device 1 ]--------------------------------------
16:29:29 | 40 >> Vulkan -   device name: GeForce GTX 745
16:29:29 | 41 >> Vulkan -   deviceID: 10DE-1382
16:29:29 | 42 >> Vulkan -   driver version: 1636843520
16:29:29 | 43 >> Vulkan -   API version: 1.0.65
16:29:29 | 44 >> Vulkan -   NVIDIA driver version: 390.65
16:29:29 | 45 >> Vulkan -   device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
16:29:30 | 46 >> - Device ID string (0): PCI\VEN_10DE&DEV_1382&SUBSYS_31101462&REV_A2
16:29:30 | 47 >> - Display device string (0): NVIDIA GeForce GTX 745
16:29:30 | 48 >> Detected graphics cards and GPUs:
16:29:30 | 49 >> - GPU 1: GeForce GTX 745
16:29:30 | 50 >> ----> DeviceID: 10DE-1382 - SubdeviceID: 1462-3110 - RevisionID: A2
16:29:30 | 51 >> ----> Config: cores:384, TMUs:0, ROPs:0
16:29:30 | 52 >> ----> TDP: 0W
16:29:30 | 53 >> ----> GPU temperature: 35.000°C
16:29:30 | 54 >> ----> Graphics driver: R390.65
16:29:30 | 55 >> ----> GPU base clock: 1032 MHz, boost clock: 1032 MHz, memory: 900 Mhz
16:29:30 | 56 >> ----> PState 0, GPU clock 540 MHz, memory clock: 900 MHz, VDDC: 0.875V:
16:29:30 | 57 >> ----> PState 8, GPU clock 405 MHz, memory clock: 405 MHz, VDDC: 0.875V:
16:29:30 | 58 >> ----> Fan speed: 42% / -1 RPM
16:29:31 | 59 >> Found 1 CUDA-capable devices.
16:29:32 | 60 >> GPU Caps Viewer startup ok.
16:29:32 | 61 >> Checking for new version...
16:29:33 | 62 >> Your version of GPU Caps Viewer is up to date
16:34:53 | 63 >> [SGX] - Plugin GpuMonitor unloaded.
16:34:53 | 64 >> GPU Caps Viewer 1.37.0.0 shutdown...
16:34:53 | 65 >> GPU Caps Viewer shutdown ok.
Re: More GPU Ino... not starting due to 0xc0000005 error
« Reply #6 on: January 15, 2018, 05:40:30 PM »
Can you run gpushark.exe in Windows explorer?
upapi_geeks
« Reply #7 on: January 15, 2018, 07:31:06 PM »
thanks for your response.
No, same problem.
But I think I have found the reason for this error. On all PC's where I tried to run gpushark.exe I use Windows Defender. In every Defender the force randomization... (ASLR) option is ACTIVATED (default: DEACTIVATED).
Setting this option to the default value, then gpushark.exe works like a charm. Btw: that is the reason why the newest GPU-Z doesn't start. The developer used a buggy EXE compressor. Solution is still undergoing.
So, I can live with the workaround not having gpushark.exe running as long as ALSR ist activated. But wouls be great, if this can be fixed someday.
regards
Uli
« Reply #8 on: January 16, 2018, 09:11:23 AM »
Thanks for your feedback upapi_geeks!
GPU Shark is also a compressed exe. I just tested with ASLR ON and indeed, GPU Shark crashed. The uncompressed version works perfectly. And good news, I just found a new exe packer that works fine with Windows Defender ASLR protection. I will update GPU Shark asap!
