Author Topic: NVIDIA Blast SDK 1.1.1  (Read 2557 times)
« on: October 31, 2017, 08:48:44 AM »
Blast is a new NVIDIA GameWorks destruction library developed to replace the APEX Destruction module.
Blast(tm) SDK 1.1.1 (10-Oct-2017)
Changes
* NvBlastProgramParams moved to NvBlastExtDamageShaders
* Materials removed from NvBlastTk
New Features
* Damage shader acceleration structure
* Extended support structures via new asset merge functions in NvBlastExtAssetUtils
* Ability to scale asset components when merging assets with NvBlastExtAssetUtilsMergeAssets
* NvBlastExtAuthoring
** Option to fit multiple convex hulls to a chunk (uses VHACD)
** deleteAllChildrenOfChunk and uniteChunks APIs
* Triangle damage shader for swept segments
* Impact damage spread shaders
Bug fixes
* Linux build fixes
** Fracturing tools chunk index fix
** VoronoiSitesGeneratorImpl::generateInSphere fix
** More consistent use of NVBLAST_ALLOC and NVBLAST_FREE
** Boolean tool bug fix
Known Issues
* Damage shaders in extensions can miss bonds if the damage volume is too small.
* Authoring code does not use the user-defined allocator (NvBlastGlobals) exclusively.
