Author Topic: IrfanView 4.50  (Read 3403 times)
IrfanView 4.50
« on: October 10, 2017, 10:10:17 PM »
Version 4.50 ( - CURRENT VERSION - ) (Release date: 2017-10-10)
    IrfanView and many PlugIns ported to Unicode!
    The INI file will be converted to Unicode if you call the "Properties" dialog
    IrfanView will NOT run on Win9x anymore
    Support for iPhone PNG files (Formats PlugIn, thanks to Jongware)
    Move selection with: CTRL or SHIFT + right mouse button (Y or X axis only)
    New option in Extract Pages/Frames dialog: Set page/frame range
    Some fixes in the Print dialog
    New text pattern: $m = show number of megapixels
    New Thumbnails sort menu: Sort by Megapixels
    Adjust print preview image to color/bw printer settings
    Wallpaper save format changed to PNG (Win8 and later)
    New zooming method: Mouse wheel alone, if "Browsing->View other files" disabled
    New command line option: /hotfolder="folder" => start Hotfolder option with a specific folder
    ANI format moved to FORMATS PlugIn
    JP2 PlugIn loading bug fixed (Talos Advisory TALOS-2017-0310)
    FPX/RLE/DJVU/ANI/SVG PlugIn loading bugs fixed (thanks to Lin Wang)
    Tools PlugIn EXE-loading problem fixed (thanks to Cody Sixteen and Lin Wang)
    Several PlugIns are ported to unicode, please install the newest versions:
