Author Topic: NVIDIA GeForce driver 384.69 for Linux, FreeBSD and Solaris  (Read 4051 times)
« on: August 22, 2017, 11:27:46 PM »
Unix Driver Archive
  • Added support for the following GPU:
    • Quadro P4000 with Max-Q Design
  • Fixed an intermittent hang when using Vulkan to present directly to display with the VK_KHR_display extension.  SteamVR was particularly affected by that hang.
  • Disabled G-SYNC in desktop environments, such as Budgie, that use libmutter-0.so.
  • An existing rule to disable G-SYNC for libmutter.so no longer applied after the library was renamed to libmutter-0.so.
  • Updated nvidia-installer to label kernel modules with SELinux file type 'modules_object_t'. Some system SELinux policies only permit loading of kernel modules with this SELinux file type.
  • Removed support for checking for and downloading updated driver packages and precompiled kernel interfaces from nvidia-installer. This functionality was limited to unencrypted ftp and http, and was implemented using code that is no longer actively maintained.
