Author Topic: NVIDIA Vulkan developer driver 382.96  (Read 2158 times)
« on: August 16, 2017, 11:24:31 PM »
  Windows driver version 382.96 and Linux driver version 381.26.13 provide new features for Vulkan developers to test their upcoming Vulkan applications.
 Windows 382.96
  Linux 381.26.13
  Release Updates   August 16th, 2017 - Windows 382.96, Linux 381.26.13
  • New Extensions
  • Updated Vulkan loader to 1.0.57.0
  • Fixed potential hang with some semaphore usage patterns
  • Fixed issue with VK_INDIRECT_COMMANDS_TOKEN_TYPE_PUSH_CONSTANT_NVX and dynamicCount
  • Other minor bugs fixed
NVIDIA developer driver 382.96 - OpenGL 4.6 + Vulkan 1.0.58
« Reply #1 on: August 18, 2017, 12:08:00 PM »
Something has changed in Vulkan sync because Vulkan demos of GPU Caps Viewer do not work anymore  >:(
Re: NVIDIA Vulkan developer driver 382.96
« Reply #2 on: August 18, 2017, 04:56:32 PM »
Works fine with GeForce 840M - Maxwell 1st gen
Do the different generations have own render paths?
« Reply #3 on: August 19, 2017, 06:53:57 PM »
Yes there are probably different render paths for the different GPU architectures.
I just fixed a bug in the GeeXLab SDK related to the management of the swapchain and now GPU Caps Viewer as well as GeeXLab work fine!
