Author Topic: NVIDIA GeForce driver 385.12 beta  (Read 2412 times)
« on: August 01, 2017, 05:03:01 PM »
This driver provides multiple Titan Xp performance optimizations on a variety of applications for prosumers and creatives.
Windows 10 64 bit
http://www.nvidia.com/download/driverResults.aspx/121776/en-us
No further explanations, i wonder if they refer to FP16 boost etc. or to Quadro features and if they are exposed on other Pascal GPUs.
@ JegX,
can you re-check the OpenGL extensions as mentioned at
http://www.geeks3d.com/20170515/test-nvidia-quadro-p5000-vs-geforce-gtx-1080/#20170515_01 ?
Happy Fête nationale btw
« Last Edit: August 01, 2017, 05:11:53 PM by Stefan »
Re: NVIDIA GeForce driver 385.12 beta
« Reply #1 on: August 01, 2017, 07:04:41 PM »
Nope I can't because I no longer have the Quadro P5000. The only Quadro I have is the K4000. Will try to test the driver with it.
Yes #SwissNationalDay  ;)
