Author Topic: Radeon GPU Profiler 1.0.1 (D3D12, Vulkan)  (Read 2178 times)
« on: July 28, 2017, 10:09:45 AM »
The Radeon GPU Profiler (RGP) is a ground-breaking low-level optimization tool from AMD.  It provides detailed timing information on Radeon Graphics using custom, built-in, hardware thread-tracing, allowing the developer deep inspection of GPU workloads.
This unique tool generates easy to understand visualizations of how your DirectX®12 and Vulkan® games interact with the GPU at the hardware level. Profiling a game is both a quick, and simple process using the Radeon Developer Panel and the public Crimson driver.
Supported GPUs:
- AMD Radeon R9 Fury and Nano series
- AMD Radeon RX 400, RX 500 series
- Radeon-GPUProfiler @ github
- Radeon GPU Profiler DOWNLOADS
Radeon GPU Profiler (RGP) v1.0.2 (D3D12, Vulkan)
« Reply #1 on: August 23, 2017, 07:55:19 AM »
V1.02 Changes
    Radeon GPU Profiler
    Added Vega support
    Added web browser-style navigation
    Keyboard navigation improvements
    Improvements to the System Activity frame visualization and frame duration data
    Select next/previous event in event timeline if the event hasn't been filtered out
    Treat SetMarker user markers as points in time and don't associate the next event with them
    Fix the ruler from disappearing when zoomed in on a 4K display
    Fix displaying of memory sizes in the Device configuration. Auto adjust to display memory units depending on memory size
    View dragging issues fixed
    Prevent loading of profiles created on unsupported hardware. The data will be unreliable if shown
    Bug/stability fixes & UI clean ups
    Linux Ctrl-C (SIGINT) handler added to RadeonDeveloperPanel and RadeonDeveloperService for clean shutdown
    Don't allow the user to attempt another connection while attempting a connection
    Extend Linux hotkey keyboard device support
    Improve application blacklist support - don't try to attach to known applications
    Fixes for connection timeout countdown issue
    Allow profiling using peak clock mode
    Miscellaneous bug/stability fixes
Link: https://github.com/GPUOpen-Tools/Radeon-GPUProfiler/releases
