Author Topic: Vulkan Synchronization Examples  (Read 1343 times)
« on: July 28, 2017, 08:19:24 AM »
Lot of synchronization examples are available here:
https://github.com/KhronosGroup/Vulkan-Docs/wiki/Synchronization-Examples
Synchronization in Vulkan can be confusing. It takes a lot of time to understand, and even then it's easy to trip up on small details. Most common use of Vulkan synchronization can be boiled down to a handful of use cases though, and this page lists a number of examples. May expand this in future to include other questions about synchronization.
Swapchain Image Acquire and Present:
VkAttachmentReference attachmentReference = {
    .attachment = 0,
    .layout     = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL};
// Subpass containing first draw
VkSubpassDescription subpass = {
    .colorAttachmentCount = 1,
    .pColorAttachments = &attachmentReference,
/* Only need a dependency coming in to ensure that the first
   layout transition happens at the right time.
   Second external dependency is implied by having a different
   finalLayout and subpass layout. */
VkSubpassDependency dependency = {
    .srcSubpass = VK_SUBPASS_EXTERNAL,
    .dstSubpass = 0,
    .srcStageMask = VK_PIPELINE_STAGE_COLOR_ATTACHMENT_OUTPUT_BIT,
    .dstStageMask = VK_PIPELINE_STAGE_COLOR_ATTACHMENT_OUTPUT_BIT,
    .srcAccessMask = 0,
    .dstAccessMask = VK_ACCESS_COLOR_ATTACHMENT_WRITE_BIT,
    .dependencyFlags = 0};
VkAttachmentDescription attachmentDescription = {
    .loadOp = VK_ATTACHMENT_LOAD_OP_DONT_CARE,
    .storeOp = VK_ATTACHMENT_STORE_OP_STORE,
    .initialLayout = VK_IMAGE_LAYOUT_UNDEFINED,
    .finalLayout = VK_IMAGE_LAYOUT_COLOR_ATTACHMENT_OPTIMAL};
VkRenderPassCreateInfo renderPassCreateInfo = {
    .attachmentCount = 1,
    .pAttachments    = &attachmentDescription,
    .subpassCount    = 1,
    .pSubpasses      = &subpass,
    .dependencyCount = 1,
    .pDependencies   = &dependency};
vkCreateRenderPass(...);
vkAcquireNextImageKHR(
    acquireSemaphore,   //semaphore
    &imageIndex);       //image index
VkPipelineStageFlags waitDstStageMask = VK_PIPELINE_STAGE_COLOR_ATTACHMENT_OUTPUT_BIT;
VkSubmitInfo submitInfo = {
    .waitSemaphoreCount = 1,
    .pWaitSemaphores = &acquireSemaphore,
    .pWaitDstStageMask = &waitDstStageMask,
    .signalSemaphoreCount = 1,
    .pSignalSemaphores = &graphicsSemaphore};
vkQueueSubmit(..., &submitInfo, ...);
VkPresentInfoKHR presentInfo = {
    .pWaitSemaphores = &graphicsSemaphore,
vkQueuePresentKHR(..., &presentInfo);
