Author Topic: NVIDIA GeForce driver 381.22 for Linux, FreeBSD and Solaris  (Read 2796 times)
Unix Driver Archive
  • Fixed a bug that caused the GLX_EXT_buffer_age buffer age extension to return incorrect values for stereo drawables when using passive stereo modes 5 through 9.
  • Fixed a bug in Vulkan direct to display where DP1.2 monitors were not being enumerated.
  • Improved compatibility with recent kernels.
  • Fixed a bug that caused "nvidia-settings --query all" to print many duplicate entries.
  • Fixed a bug that caused applications to crash in some situations when calling glXMakeCurrent while OpenGL threaded optimizations were enabled. This frequently occurred when Steam was attempting to make a video appear full-screen.
  • Fixed a bug that caused VDPAU applications to use the blit presentation queue when a previous VDPAU application didn't shut down cleanly.
  • Fixed hangs and crashes that could occur when an OpenGL context is created while the system is out of available memory.
  • Fixed a bug that caused corruption when OpenGL windows were moved or resized.
  • Fixed a bug that caused X screens that use Option "UseDisplayDevice" "none" to be resized to 640x480 when using "xrandr -s" to change the screen configuration.
  • Fixed a kernel crash that occurred when attempting to map large user memory allocations into CUDA.
  • Disabled OpenGL threaded optimizations by default, initially enabled in 378.09, due to various reports of instability.
  • Added support for the following Vulkan extensions:
    • VK_EXT_acquire_xlib_display
      VK_EXT_display_control
      VK_EXT_display_surface_counter
      VK_EXT_direct_mode_display
      VK_KHX_external_memory
      VK_KHX_external_memory_fd
      VK_KHX_external_semaphore
      VK_KHX_external_semaphore_fd
    These extensions require a Vulkan loader version >= 1.0.42.
  • Removed the X driver's logo splash screen and the corresponding NoLogoand LogoPath xorg.conf options.
  • Added the "ResamplingMethod" MetaMode option, adding support for bicubic resampling methods when scaling screen transformations are in use.  See the README for more details.
